Highlighted
Explorer
Upgrade Path Justification
on a CM and CUC 8.6 install can anyone provide rationale for going to 11 as opposed to 10.5?  I'm told that 10.5 is more stable on both applications but am being pressed to go to 11 to get the latest and greatest.
All replies rated.
Thanks!!
2 REPLIES 2
Well, you should really start
Well, you should really start from looking at the v11 Release Notes for both these products to check what extra you are getting and do you really need them or not??
11.x had been there from some time and is quite stable as well but as mentioned above, it really depends on what you are looking to get and is it only achievable with a specific version. If yes, then you will/should definitely go to that version only
Deepak
Hall of Fame Cisco Employee
Historically .0 releases have
Historically .0 releases have a very short span of life until the MR comes out, if they want to upgrade and leave things be for a good time, you might want to think on 10.5, if they want to go to 11.x for some specific new feature no previous version has, they might have to upgrade really soon, when 11.5 comes out.
java
if this helps, please rate
Content for Community-Ad
July's Community Spotlight Awards
