03-30-2016 08:06 AM - edited 03-17-2019 06:24 AM
on a CM and CUC 8.6 install can anyone provide
All replies rated.
Thanks!!
03-30-2016 08:18 AM
Well, you should really start from looking at the v11 Release Notes for both these products to check what extra you are getting and do you really need them or not??
11.x had been there from some time and is quite stable as well but as mentioned above, it really depends on what you are looking to get and is it only achievable with a specific version. If yes, then you will/should definitely go to that version only
Deepak
03-30-2016 08:44 AM
Historically .0 releases have a very short span of life until the MR comes out, if they want to upgrade and leave things be for a good time, you might want to think on 10.5, if they want to go to 11.x for some specific new feature no previous version has, they might have to upgrade really soon, when 11.5 comes out.
