Cisco Community Designated VIP Class of 2020
760
Highlighted
Beginner
Upgrade UCCX 9.0.2 to 11.5 error not valid MD5
Hi Team
I'm in process to upgrade UCCX version 9.0.2 to version 11.5, i installed the ciscouccx.refresh_upgrade_v1.11.cop.sgn and the ciscocm.version3-keys.cop.sgn but all the installation fails whit the error in the image attached
The documentation has the target available for fresh install: https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cust_contact/contact_center/crs/express_11_5/install/guide/uccx_b_uccx-install-upgrade-guide/uccx_b_uccx-install-upgrade-guide_chapter_011.html#task_67CEFFA34C37BF7882A5206F2BE7D3A3
Thanks every one for yor help.
Upgrade Scenario
Tasks
10.0.x to 11.5.x
9.x.x to 11.5.x
Single Node Setup:
  1. Apply COP File, so that when you upgrade later, the system can detect whether the upgrade is an RU or not.
    1. Go to URL: http:/​/​software.cisco.com/​download/​navigator.html
    2. Enter your username and password and click Log In.
    3. Choose from the list Products > Customer Collaboration > Contact Center Solutions > Unified Contact Center Express > Unified Contact Center Express 11.5(1).
    4. Click Unified Contact Center Express Upgrade Utilities.
    5. Download the COP file.
  2. Upgrade Unified CCX Using Web Interface or Upgrade Unified CCX Using CLI
  3. Check and Perform Switch Version.
  4. Verify Version of Unified CCX
  5. Verify Status of Services
  6. Upgrade Unified CCX Clients
6 REPLIES 6
VIP Advisor
Re: Upgrade UCCX 9.0.2 to 11.5 error not valid MD5
Did you install 'ciscocm.version3-keys.cop.sgn' on all nodes in the cluster. From CLI apply this command and post the output file view install system-history.log
Beginner
Ho Mohamed
Thes the keys are installed on both servers, and thos is the command output.
03/31/2017 11:56:25 | root: DRS Backup UCMVersion:9.0.2.11001-24 Start
03/31/2017 12:02:14 | root: DRS Backup UCMVersion:9.0.2.11001-24 Success
04/07/2017 11:58:03 | root: DRS Backup UCMVersion:9.0.2.11001-24 Start
04/07/2017 12:03:33 | root: DRS Backup UCMVersion:9.0.2.11001-24 Success
04/14/2017 11:59:42 | root: DRS Backup UCMVersion:9.0.2.11001-24 Start
04/14/2017 12:04:07 | root: DRS Backup UCMVersion:9.0.2.11001-24 Success
04/21/2017 12:01:21 | root: DRS Backup UCMVersion:9.0.2.11001-24 Start
04/21/2017 12:07:35 | root: DRS Backup UCMVersion:9.0.2.11001-24 Success
04/28/2017 12:03:00 | root: DRS Backup UCMVersion:9.0.2.11001-24 Start
04/28/2017 12:08:51 | root: DRS Backup UCMVersion:9.0.2.11001-24 Success
05/05/2017 12:04:39 | root: DRS Backup UCMVersion:9.0.2.11001-24 Start
05/05/2017 12:10:20 | root: DRS Backup UCMVersion:9.0.2.11001-24 Success
options: q=quit, n=next, p=prev, b=begin, e=end (lines 301 - 320 of 387) :
05/12/2017 12:06:19 | root: DRS Backup UCMVersion:9.0.2.11001-24 Start
05/12/2017 12:13:04 | root: DRS Backup UCMVersion:9.0.2.11001-24 Success
05/19/2017 12:08:02 | root: DRS Backup UCMVersion:9.0.2.11001-24 Start
05/19/2017 12:19:29 | root: DRS Backup UCMVersion:9.0.2.11001-24 Success
05/22/2017 18:40:19 | root: Boot 9.0.2.11001-24 Start
05/26/2017 11:55:55 | root: DRS Backup UCMVersion:9.0.2.11001-24 Start
05/26/2017 12:03:05 | root: DRS Backup UCMVersion:9.0.2.11001-24 Success
06/02/2017 11:57:33 | root: DRS Backup UCMVersion:9.0.2.11001-24 Start
06/02/2017 12:04:27 | root: DRS Backup UCMVersion:9.0.2.11001-24 Success
06/07/2017 09:00:28 | root: Boot 9.0.2.11001-24 Start
06/09/2017 11:55:32 | root: DRS Backup UCMVersion:9.0.2.11001-24 Start
06/09/2017 12:02:30 | root: DRS Backup UCMVersion:9.0.2.11001-24 Success
06/16/2017 11:57:10 | root: DRS Backup UCMVersion:9.0.2.11001-24 Start
06/16/2017 12:04:05 | root: DRS Backup UCMVersion:9.0.2.11001-24 Success
06/23/2017 11:58:49 | root: DRS Backup UCMVersion:9.0.2.11001-24 Start
06/23/2017 12:05:35 | root: DRS Backup UCMVersion:9.0.2.11001-24 Success
06/30/2017 12:00:28 | root: DRS Backup UCMVersion:9.0.2.11001-24 Start
06/30/2017 12:07:07 | root: DRS Backup UCMVersion:9.0.2.11001-24 Success
07/07/2017 12:02:08 | root: DRS Backup UCMVersion:9.0.2.11001-24 Start
07/07/2017 12:12:28 | root: DRS Backup UCMVersion:9.0.2.11001-24 Success
options: q=quit, n=next, p=prev, b=begin, e=end (lines 321 - 340 of 387) :
07/09/2017 05:54:16 | root: Shutdown 9.0.2.11001-24 Start
07/09/2017 11:31:25 | root: Boot 9.0.2.11001-24 Start
07/09/2017 13:06:37 | root: Boot 9.0.2.11001-24 Start
07/14/2017 11:56:11 | root: DRS Backup UCMVersion:9.0.2.11001-24 Start
07/14/2017 12:02:57 | root: DRS Backup UCMVersion:9.0.2.11001-24 Success
07/21/2017 11:57:50 | root: DRS Backup UCMVersion:9.0.2.11001-24 Start
07/21/2017 12:04:25 | root: DRS Backup UCMVersion:9.0.2.11001-24 Success
07/28/2017 11:59:29 | root: DRS Backup UCMVersion:9.0.2.11001-24 Start
07/28/2017 12:05:27 | root: DRS Backup UCMVersion:9.0.2.11001-24 Error
08/04/2017 12:01:08 | root: DRS Backup UCMVersion:9.0.2.11001-24 Start
08/04/2017 12:06:52 | root: DRS Backup UCMVersion:9.0.2.11001-24 Error
08/11/2017 12:02:47 | root: DRS Backup UCMVersion:9.0.2.11001-24 Start
08/11/2017 12:08:33 | root: DRS Backup UCMVersion:9.0.2.11001-24 Error
08/18/2017 12:04:27 | root: DRS Backup UCMVersion:9.0.2.11001-24 Start
08/18/2017 12:10:25 | root: DRS Backup UCMVersion:9.0.2.11001-24 Error
08/25/2017 12:06:05 | root: DRS Backup UCMVersion:9.0.2.11001-24 Start
08/25/2017 12:12:11 | root: DRS Backup UCMVersion:9.0.2.11001-24 Error
09/08/2017 12:09:23 | root: DRS Backup UCMVersion:9.0.2.11001-24 Start
09/08/2017 12:16:57 | root: DRS Backup UCMVersion:9.0.2.11001-24 Success
09/15/2017 12:11:02 | root: DRS Backup UCMVersion:9.0.2.11001-24 Start
options: q=quit, n=next, p=prev, b=begin, e=end (lines 341 - 360 of 387) :
09/15/2017 12:18:39 | root: DRS Backup UCMVersion:9.0.2.11001-24 Success
09/22/2017 12:12:42 | root: DRS Backup UCMVersion:9.0.2.11001-24 Start
09/22/2017 12:20:20 | root: DRS Backup UCMVersion:9.0.2.11001-24 Success
09/29/2017 12:14:20 | root: DRS Backup UCMVersion:9.0.2.11001-24 Start
09/29/2017 12:22:08 | root: DRS Backup UCMVersion:9.0.2.11001-24 Success
10/06/2017 12:16:00 | root: DRS Backup UCMVersion:9.0.2.11001-24 Start
10/06/2017 12:25:43 | root: DRS Backup UCMVersion:9.0.2.11001-24 Success
10/13/2017 12:17:44 | root: DRS Backup UCMVersion:9.0.2.11001-24 Start
10/13/2017 12:32:35 | root: DRS Backup UCMVersion:9.0.2.11001-24 Success
10/20/2017 12:19:18 | root: DRS Backup UCMVersion:9.0.2.11001-24 Start
10/20/2017 12:28:12 | root: DRS Backup UCMVersion:9.0.2.11001-24 Success
10/27/2017 12:20:57 | root: DRS Backup UCMVersion:9.0.2.11001-24 Start
10/27/2017 12:29:44 | root: DRS Backup UCMVersion:9.0.2.11001-24 Success
11/03/2017 12:22:36 | root: DRS Backup UCMVersion:9.0.2.11001-24 Start
11/03/2017 12:30:48 | root: DRS Backup UCMVersion:9.0.2.11001-24 Success
11/09/2017 22:13:56 | root: Boot 9.0.2.11001-24 Start
11/10/2017 11:55:12 | root: DRS Backup UCMVersion:9.0.2.11001-24 Start
11/10/2017 11:59:01 | root: DRS Backup UCMVersion:9.0.2.11001-24 Warning
11/18/2017 11:31:35 | root: Cisco Option Install ciscouccx.refresh_upgrade_v1.11.cop Start
11/18/2017 11:35:30 | root: Cisco Option Install ciscouccx.refresh_upgrade_v1.11.cop Success
options: q=quit, n=next, p=prev, b=begin, e=end (lines 361 - 380 of 387) :
11/18/2017 11:40:07 | root: Restart 9.0.2.11001-24 Start
11/18/2017 11:40:41 | root: Restart 9.0.2.11001-24 Start
11/18/2017 11:42:14 | root: Boot 9.0.2.11001-24 Start
11/18/2017 12:19:45 | root: Cisco Option Install ciscocm.version3-keys.cop Start
11/18/2017 12:19:45 | root: Cisco Option Install ciscocm.version3-keys.cop Success
11/18/2017 12:21:43 | root: Restart 9.0.2.11001-24 Start
11/18/2017 12:24:12 | root: Boot 9.0.2.11001-24 Start
VIP Advisor
Have you tried to restart cucm nodes and see if the upgrade goes through
Beginner
Hi, yes and the active version in ethe cluster is 9.1 and the inactive are 11.5.
VIP Advisor
Tou are running 9.0(2). Can you try to go to 9.1 then to 11.5. I know the
upgrade path says that you can go direct but just a thought
Beginner
Hi, yesterday upgrade to latest version of 9,0 (9.0.2.11002-27), an today the iso to upgrade proceess pass, but stops in sme point, can you check the ouput attached? Thanks a lot
Content for Community-Ad
FusionCharts will render here
