04-09-2015 08:39 AM - edited 03-18-2019 11:29 AM
Hi everyone,
I'm trying to upgrade from CUCM 8.5 to 9.1.2. A cop file has to be installed called ciscocm.refresh_upgrade_v1.3.cop.sgn (I have used it before) but I can't find it anywhere only find version 5 (ciscocm.refresh_upgrade_v1.5.cop.sgn).
My question is, Does Refresh-Upgrade-Version-5 replace version 3? If the answer if no, where could I locate the file?
Solved! Go to Solution.
04-09-2015 08:53 AM
Yes, that's just the most recent release for it.
04-09-2015 08:53 AM
04-09-2015 02:31 PM
Thanks Jaime!
Rob(+5) for you too.
04-09-2015 11:30 PM
Hi Leo,
you can also refer the link
regds,
aman
04-09-2015 09:06 AM
Hi Leo,
Hope all is well my friend!
Java is most correct here (+5)
This RU version contains the latest bug fixes;
Updates in This Release As RU updates are cumulative, installing this patch provides all the fixes in the New Updates and Previous Updates sections.
New Updates
CSCuo29837 8.5.1 to 10.0 upgrade failing on the installdb[check for presence of \0]
CSCue04145 SIP Normalization scripts got scrambled during RU upgrade
From;
http://www.cisco.com/web/software/282204704/18582/ciscocm.refresh_upgrade_v1.5.pdf
Cheers!
Rob
