Upgrading CME checklist
fearless.rabbit
Hello dear friends,
I have CME 8 on ISR3945e running IOS 15.1(2)T. Basically, I need to upgrade both IOS and CME, with respective 69xx phone images because Im having an immensity of bugs Now, I have newer version of IOS, and I wonder do I need CME files separately, or they come with IOS? Is there anything else I need to do except upgrade IOS and restore the config file? Something else to download?
Thank you
Here is output from sh ver, just in case:
ISR3945#sh ver
Cisco IOS Software, C3900 Software (C3900-UNIVERSALK9-M), Version 15.1(2)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Mon 19-Jul-10 20:13 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M1, RELEASE SOFTWARE (fc1)
ISR3945 uptime is 1 year, 4 weeks, 9 hours, 35 minutes
System returned to ROM by address error at PC 0x8F508D0, address 0x61636865 at 12:36:57 MNE Tue Jan 24 2012
System restarted at 03:00:12 MNE Thu Apr 26 2012
System image file is "flash:c3900-universalk9-mz.SPA.151-2.T.bin"
Last reload type: Normal Reload
Cisco CISCO3945-CHASSIS (revision 1.0) with C3900-SPE150/K9 with 983040K/65536K bytes of memory.
Processor board ID FCZ1413701E
5 Gigabit Ethernet interfaces
31 Serial interfaces
2 terminal lines
1 Channelized E1/PRI port
DRAM configuration is 72 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
254464K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#           PID                              SN
*0             C3900-SPE150/K9       FOC14106Y7H
Technology Package License Information for Module:'c3900'
Technology    Technology-package          Technology-package
              Current       Type          Next reboot
ipbase        ipbasek9      Permanent     ipbasek9
security      None          None          None
uc            uck9          Permanent     uck9
data          None          None          None
Chris Deren
CME is built into IOS, you may just need to upgrade GUI files and firmware versions which are all downloadable for specific version of CME on CCO.
HTH,
Chris
Chris Deren
HTH,
Chris
Thanks for replying. Just to confirm, I am getting CME with IOS. All I need "extra" are individual firmware files for phones?
Correct, plus the GUI files if you care for them.
Chris
Much appreciated!
