Upgrading from 4.1(2) to 4.1(3)
alan_joseph
Is it possible to restore a 4.1(2) DB on a 4.1(3) server? I would rather do a fresh install of 4.1(3), and just restore my DB than performing the upgrade process, so as to minimize downtime.
Thanks!
Alan Joseph III
CCIE # 17190
2 Accepted Solutions
Tommer Catlin
Nope, you will need to run the upgrade process. Unless TAC has some engineering tool that is not published, but typically you must run the upgrade process. Start with 4.1.2, then upgrade to 4.1.3 because it does actually change the database slightly. (add features, updates, etc)
Rob Huffman
Hi Alan,
This is not a supported method :(
Have a look at the following tech notes;
Procedure
Step 1 Reinstall the operating system on the publisher database server.
Choose the Same Server Recovery option during the operating system installation to ensure that the original information you entered during the initial operating system installation displays in the appropriate fields.
Step 2 Reinstall Cisco CallManager on the publisher database server.
***Make sure that the Cisco CallManager version that is installed on the server matches the version of the latest successful publisher database server backup.***
Step 3 Restore the data to the publisher database server.
From this doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_installation_guide_chapter09186a00801ebeae.html#wp1029778
Restore Location When You Have Two Different Versions of Cisco CallManager
Tip ***Do a system restore on the same Cisco CallManager version. Changes from release to release cause problems if you try to restore from a different version.***
From this doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/prod_troubleshooting_guide_chapter09186a00802e0e9d.html#wp1098890
After a Restore, Database Is Corrupt
Symptom
A backup and restore appear to successfully complete on the publisher and subscriber servers but one database is missing information. Each database shows different versions of the software.
Possible Cause
***A backup was made of one version, and the restore was to a newer software version.***
Recommended Action
***You must do a system restore on the same Cisco CallManager version. Changes from release to release would cause problems if you tried to restore from a different version.***
From this doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/prod_troubleshooting_guide_chapter09186a00802e0e9d.html#wp1108155
Hope this helps!
Rob
Tommer Catlin
Rob Huffman
Hi Alan,
Procedure
From this doc;
From this doc;
Symptom
Possible Cause
Recommended Action
From this doc;
Hope this helps!
Rob
alan_joseph
Thanks for the assist ...
Installed the OS-Update 2000.7.sr8 then ran the 4.1(3) upgrade, after searching high and low for the upgrade assistant (why don't they put these things in the same places?) and it installed like a champ.
Ran the 4.1(3)sr4b and now my 7961G-GE phones are registering ... the whole reason for sparking my upgrade.
Thanks.
