09-20-2011 12:44 PM - last edited on 03-25-2019 08:09 PM by ciscomoderator
Has anyone had any experience with upgrading from 6x to 8.5.x? We just completed a cluster upgrade from 6 to 8 and had a horrible time with the ITL files. We eended up having to delete these files on over 600 phones before they would register correctly. Now that we are moving to the next cluster for some odd reason the ITL files are not showing up on the phones at all. I am fine with this but why? We have not made any changes in the Enterprise Parameters such as modify the rollback pre 8.0. From what we can tell, there is not reason as to why the ITL files shoud not be on the phone. As it stands now I can register any phone type between this 8.5.1 cluster to 6.1.3 back to 8.5.1 without any issues. This is because there isnt any ITL file.
Chad
09-20-2011 01:24 PM
If the phone firmware didn't upgrade, so if it is still pre-9.x the phone will not request an ITL file. If the phone is upgraded to 9.x it will request and should get an ITL file with CUCM 8.x.
09-20-2011 01:33 PM
Joe,
We are running firmware version 9.1.1 on the phones and they are registered to 8.5.1 without any sort of ITL file. This is what's puzzling.
Any ideas?
Chad
09-21-2011 01:18 PM
From the pub when doing show itl, the following error pops up:
ITL Record #:7
BYTEPOS TAG LENGTH VALUE
1 RECORDLENGTH 2 719
2 DNSNAME 2
3 SUBJECTNAME 64 CN=jp01-cucm-01;OU=Synopsys;O=Synopsys;L=Synopsy s;ST=Japan;C=JP
4 FUNCTION 2 TVS
5 ISSUERNAME 64 CN=jp01-cucm-01;OU=Synopsys;O=Synopsys;L=Synopsy s;ST=Japan;C=JP
6 SERIALNUMBER 8 5B:6D:0C:1E:09:23:E8:95
7 PUBLICKEY 270
8 SIGNATURE 256
11 CERTHASH 20 5D 21 EC EE 21 07 4A 0C DB 4E 0C E9 80 2E 01 D3 88 22 19 F9
12 HASH ALGORITHM 1 SHA-1
Verification of the ITL file failed.
Error parsing the ITL File !!!
admin:
09-21-2011 01:33 PM
Thanks for sharing that. It looks like the ITL file is corrupt, I haven't seen that before. Do you have a TAC case open for this by chance?
09-21-2011 02:37 PM
By sheer coincidence, I'm having a very similar problem. The ITL file on my primary TFTP server is permantly corrupt. (My backup TFTP server on my publisher is fine)
TAC's initial suggestion was to stop the TFTP process, delete the ITL file, then restart the TFTP process. This worked once, and the ITL file stayed valid for about a week. After that, the ITL file became corrupt and won't get valid again.
TAC are going to WebEx onto my system tomorrow. I'll let you know if they fix it.
BTW - I'm on CUCM 8.6
GTG
09-21-2011 02:40 PM
Here is the fix:
Regenerate the following under OS and Security:
Call Manager pem/der
TVS pem/der
Tomcat pem/der
Perform a BACKUP!!!!
Restart TVS then TFTP services. Then, you are all set.
Chad
09-21-2011 02:44 PM
Hmm. With those certificates being regenerated, I'm surprised you don't have to bounce the box !
I'll have a play with that on my test cluster.
Thanks for the suggestion.
GTG
09-21-2011 02:46 PM
No need to bounce the server. Just restart the Trust Services and TFTP server on the node in which you regenerate the licenses.
Chad
09-21-2011 02:49 PM
I'd have thought the Tomcat cert would require Tomcat restarting, at least. I haven't clue what relies on the CallManager cert (Such an innocent sounding name for a certificate on a CallManager system...)
GTG
09-21-2011 03:18 PM
Be careful if these are production systems with regenerating the callmanager certificate. Doing this changes the TFTP private key used for the ITL, meaning if you regenerate the callmanager certificate, you will have to manually delete the ITL from your phones because they will not trust the new one. If you have multiple servers (some without corrupt ITL files) you can follow this guide to not have to delete each phone's ITL manually (
09-21-2011 03:29 PM
Deleting the ITL file from every phone is not an option for me.
Thanks for the heads-up.
GTG
09-21-2011 03:44 PM
In my case this is not applicable as I don’t have any ITl’s… mine are corrupt.
Chad
