Cisco Community Designated VIP Class of 2020
137
Highlighted
Upgrare standalone ELM to PLM.
Hi all.
I want to upgrade my standalone ELM to PLM. Is it possible or I need to install the new PLM and transfer my license to it because there is the different in vm template ? ELM require 1x 80 GB of vDisk and PLM require  1x 50 GB of vDisk.
2 REPLIES 2
Hall of Fame Cisco Employee
You can upgrade, if you want
You can upgrade, if you want to use the smaller HDD ova, you would need to do a fresh install and migrate the licenses.
java
if this helps, please rate
Will i get eny erroro about
Will i get eny error about vDisk afterupgrade ? Does TAC support this confuguration ?
Content for Community-Ad
FusionCharts will render here
