URGENT - BRI voice card
shane.oconnell
Hi all,
Firstly, we have run into a serious issue in a remote office installation where it turns out that the voice card we have does not support voice. It is:
HWIC-4B-S/T
Now I need to know if the following card does support voice:
WIC-1B-S/T V3
Does anyone know if the above supports voice and if it does not, can you recommend a BRI card that will support voice?
Rob Huffman
Hi Shane,
Sadly that module does not support Voice
Here is one choice;
VIC2-2BRI-NT/TE
http://www.cisco.com/en/US/prod/collateral/modules/ps5365/product_data_sheet0900aecd801c595e.html
Cheers!
Rob
Rob Huffman
Hi Shane,
Here is one choice;
VIC2-2BRI-NT/TE
Cheers!
Rob
paolo bevilacqua
May I make a comment and please don't get offended by it.
Do you use a reputable consultant, or certified Cisco partner when designing and implementing your network?
Because your issue is of the type that happens when one doesn't.
