06-16-2013 09:46 AM - edited 03-16-2019 05:54 PM
we have CUCM version 8.6.2(20000)-2 in UCS and did a cluster reboot of 1pub+ 4sub. pub and 1 sub came up.
another 3 nodes were started but the CCM and CTI services were stopped. any
admin:utils service list
Requesting service status, please wait...
System SSH [STARTED]
Cluster Manager [STARTED]
Service Manager is running
Getting list of all services
>> Return code = 0
A Cisco DB[STARTED]
A Cisco DB Replicator[STARTED]
Cisco AMC Service[STARTED]
Cisco Audit Event Service[STARTED]
Cisco CAR DB[STOPPED] Commanded Out of Service
Cisco CAR Scheduler[STOPPED] Commanded Out of Service
Cisco CDP[STARTED]
Cisco CDP Agent[STARTED]
Cisco CDR Agent[STARTED]
Cisco CDR Repository Manager[STOPPED] Commanded Out of Service
Cisco CTIManager[STOPPED] Component is not running
Cisco CallManager[STOPPED] Component is not running
Cisco CallManager Admin[STARTED]
Cisco CallManager Cisco IP Phone Services[STARTED]
Cisco CallManager Personal Directory[STARTED]
Cisco CallManager Serviceability[STARTED]
Cisco CallManager Serviceability RTMT[STARTED]
Cisco Certificate Change Notification[STARTED]
Cisco Certificate Expiry Monitor[STARTED]
Cisco Change Credential Application[STARTED]
Cisco DRF Local[STARTED]
Cisco DRF Master[STOPPED] Commanded Out of Service
Cisco Database Layer Monitor[STARTED]
Cisco Extension Mobility Application[STARTED]
Cisco IP Manager Assistant[STARTED]
Cisco IP Voice Media Streaming App[STARTED]
Cisco License Manager[STARTED]
Cisco Log Partition Monitoring Tool[STARTED]
Cisco RIS Data Collector[STARTED]
Cisco RTMT Reporter Servlet[STARTED]
Cisco SOAP - CallRecord Service[STOPPED] Commanded Out of Service
Cisco Syslog Agent[STARTED]
Cisco Tftp[STARTED]
Cisco Tomcat[STARTED]
Cisco Tomcat Stats Servlet[STARTED]
Cisco Trace Collection Service[STARTED]
Cisco Trace Collection Servlet[STARTED]
Cisco Trust Verification Service[STARTED]
Cisco User Data Services[STARTED]
Host Resources Agent[STARTED]
MIB2 Agent[STARTED]
SNMP Master Agent[STARTED]
SOAP - Diagnostic Portal Database Service[STARTING]
SOAP -Log Collection APIs[STARTING]
SOAP -Performance Monitoring APIs[STARTING]
SOAP -Real-Time Service APIs[STARTING]
System Application Agent[STARTED]
Cisco AXL Web Service[STOPPED] Service Not Activated
Cisco Bulk Provisioning Service[STOPPED] Service Not Activated
Cisco CAR Web Service[STOPPED] Service Not Activated
Cisco CTL Provider[STOPPED] Service Not Activated
Cisco CallManager SNMP Service[STOPPED] Service Not Activated
Cisco Certificate Authority Proxy Function[STOPPED] Service Not Activated
Cisco DHCP Monitor Service[STOPPED] Service Not Activated
Cisco Dialed Number Analyzer[STOPPED] Service Not Activated
Cisco Dialed Number Analyzer Server[STOPPED] Service Not Activated
Cisco DirSync[STOPPED] Service Not Activated
Cisco Extended Functions[STOPPED] Service Not Activated
Cisco Extension Mobility[STOPPED] Service Not Activated
Cisco Messaging Interface[STOPPED] Service Not Activated
Cisco SOAP - CDRonDemand Service[STOPPED] Service Not Activated
Cisco Serviceability Reporter[STOPPED] Service Not Activated
Cisco TAPS Service[STOPPED] Service Not Activated
Cisco UXL Web Service[STOPPED] Service Not Activated
Cisco Unified Mobile Voice Access Service[STOPPED] Service Not Activated
Cisco WebDialer Web Service[STOPPED] Service Not Activated
Platform SOAP Services[STOPPED] Service Not Activated
Primary Node =false
can someone help us in this highy critical issue please?
06-16-2013 10:24 AM
Hi Suresh,
Did u try restarting the services manually ?
Is this the first time u booted and problem came?
regds,
aman
06-16-2013 11:30 AM
Hi Aman, yes, we tried restarting the service manually but it gives us error saying "Invalid service list" and this is fist time we do the cluster reboot
06-16-2013 11:44 AM
Do you have enough node licenses?
If so, you need to look at the logs, as everything else would just be a guess.
HTH,
Chris
06-16-2013 12:10 PM
yes, we do have enough node licences. I'm collecting, CCM, CTI traces and syslog and event logs.
could you please let me know what more should i look into if any?
06-16-2013 05:07 PM
Start the server, wait until it stops and then look for the events in the logs and see what it complains about, there is no magic message here, you can search for "error", "exception", etc.
HTH,
Chris
