12-18-2016 05:48 AM - edited 03-17-2019 08:59 AM
what is the steps I should follow to make the phone registered to CME router version 10.0 using IOS 15.4
voice register dn 2
number 3000
name Jaber-Android
voice register pool 2
registration-timer max 720 min 660
id mac 1C99.4C71.9184
session-transport tcp
type Jabber-Android
number 1 dn 2
dtmf-relay rtp-nte
username test password test123
codec g711ulaw
this is what I did on router.
12-18-2016 09:33 PM
Jabber for Android is not supported with CME 10.0 as per the following
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/requirements/guide/cme10spc.html
Manish
12-19-2016 12:12 AM
Hi Manish,
Thanks for help.
can you please tell what is configuration required on router to jabber for windows
also what version of jabber will be supported if i would use Windows 7 or 8 or 10
Also is Iphone supported if yes what version if mobile ios supported and what version of jabber for iphone.
