Users get fast busy when trying a specific extension
cigalahgroup
I received an old call manager server 4.1. when calling a particular extension there is a fast busy tone I tried removing the number completely from CallManager and then adding it again but the same results.
I removed from unassigned dn but the same issue presists.
6 Replies 6
Dennis Mink
is the phone with that extension registered?  try putting it in the same partition and css as the calling phone and try again
Please remember to rate useful posts, by clicking on the stars below.
yes the phones is registered and it shows the ip, I did put in the partition and css both still.
What I see weird is one the phone is added it goest unassigned in the route pattern plan
i dont quite follow. can you add a screenshot?
Please check the screen shot
Can you please post a screenshot of all patterns and URI for extension 8384?
Thanks a lot
Carlo
Please rate all helpful posts "The more you help the more you learn"
