Users not available to add to line group
nigelibbertson
Beginner
Beginner
I am trying to add users to a new line group but some of the users I would like to add are not showing up in the list as available.
The common link between them is that they are all IPCC agents will that stop them being added to a new line group or is something else stopping me adding them?
Nigel
Rob Huffman
Hall of Fame Community Legend Hall of Fame Community Legend
Hi Nigel,
I would think you may be hitting this restriction;
End points not supported in hunt groups
— Do not assign agent phones, CTI ports, or route points
that are used by Unified CCX to hunt groups.
From;
http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/crs/express_8_5/release/guide/uccx851rn.pdf
Cheers!
Rob
"What you don't have you don't need it now"
- U2
Anas Abueideh
Engager
Engager
it should be available for line group. It doesn't matter if it is IPCC extension or not. Did you try to search in the list available.
Anas
please rate if it is helpful
Rob Huffman
Hi Nigel,
From;
Cheers!
Rob
- U2
Rob is absolutely correct (+5 buddy), it has never been supported to add contact center DNs to line groups, however I have never seen this actually being enforced.  In either case you should not be adding them as that may lead to issues.  What I do in environments that require backup hunting for call centers is assign the personal DNs of the agents to the line groups.
HTH,
Chris
