Users wants to have their Actual DID on Outgoing Calls
Hi All,
We are using CUCM System version: 8.5.1. we have a Board line number +91 44 4404 4000, the DIDs starts from +91 44 4404 4000 to +91 44 4404 4099.
at present when the user dial an outbound call their number displays as +91 44 4404 4000 (Board line number), but they want their actual DID to be displayed instead.
Please assist.
let me know for any clarification.
Thanks in Advance.
SIva.
9 REPLIES 9
Beginner
can you post the voice
can you post the voice gateway config
voice-card 0!!!voice service
voice-card 0
voice service voip
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 supplementary-service h450.12
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 h323
  h225 h245-address on-connect
 sip
  registrar server expires max 3600 min 3600
voice class codec 99
 codec preference 1 g711ulaw
voice class h323 1
  h225 timeout tcp establish 3
hw-module pvdm 0/0
controller E1 0/0/0
 framing NO-CRC4
 pri-group timeslots 1-31 service mgcp
controller E1 0/0/1
 framing NO-CRC4
interface Serial0/0/0:15
 no ip address
 encapsulation hdlc
 isdn switch-type primary-net5
 isdn incoming-voice voice
 isdn bind-l3 ccm-manager
 no cdp enable
ccm-manager redundant-host 192.168.1.11
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 192.168.1.10 192.168.1.11
ccm-manager config
ccm-manager sccp local GigabitEthernet0/0
mgcp
mgcp call-agent 192.168.1.10 2427 service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface GigabitEthernet0/0
mgcp bind media source-interface GigabitEthernet0/0
mgcp profile default
Beginner
in case of MGCP the
in case of MGCP the configuration is in the CUCM
check the transform mask in the dial patterns. also check the translation patterns
Hall of Fame Cisco Employee
The easiest way would be to
The easiest way would be to hardcode their own external phone number mask at DN level, and then make sure to check the option in the RP to use it for outbound calls.
java
if this helps, please rate
Beginner
Hi Siva, In this case please
Hi Siva,
In this case please let us know if the internal extensions have the same mask i.e 4000 to 4099 or different extensions.
Mohamed Bedawy
Regards, Mohamed Helmy
Hi Mohamed,Internal
Hi Mohamed,
Internal extensions have different mask
+91 44 4404 4000 to +91 44 4404 4099   >>  9200 to 9299
Siva.
Hi Mohamed,  Any idea..
Hi Mohamed,
Any idea..
SIva.
Beginner
hi Siva, as the extensions
hi Siva,
as the extensions are not in the same range, so the best way will be as our expert Jaime said. hard code each directory number with external phone number musk with his external number.
other ways will take a lot of work.
Regards.
Highlighted
Beginner
Go toCall Routing > Route
Go to
Call Routing > Route/Hunt > Route List > (Choose the Route List used by your route pattern then click on it)
After, click on Route List Details (figure 1.png) and make sure that the field Use Calling Party's External Phone Number Mask Required Field is set to Active (figure 2.png)
Hope this helps!
Content for Community-Ad
July's Community Spotlight Awards
