06-15-2011 08:36 AM - editado 03-16-2019 05:28 AM
We have a request from our senior management teams to find a way to block the outgoing caller ID on a per call basis. We are trying to find a way to get a route pattern to work with *67. I have tried *679.1[2-9]xx[2-9]xxxxxx and also *9*67.1[2-9]xx[2-9]xxxxxx, niether of these patterns works, the caller ID still goes through.
Has anyone in the support network here set this up and gotten it to work? We are running on call manager 7.1.3.
Please let me know if you do.
Thank you.
Rgds,
Vicky
Solucionado! Ir para a Solução.
em 06-15-2011 08:42 AM
Use a translation pattern (*67.91XXXXXXXXXX, *67.9XXXXXXXXXX) instead of a route pattern and set the
em 06-15-2011 10:56 AM
Hi Dave,
The restricted setting did the trick for us. Thank you so much for the post!
em 06-15-2011 08:43 AM
Hi Vicky,
Caller-ID could still be going through because you are more then likely doing pre-dot digit strip on your Call Manager and it is stripping off the *679.
Wherever you are doing your manipulation, simply do your normal predot and put prefix *67 and it should prepend that to your number to the PSTN.
HTH,
Chris
Please rate helpful posts
em 07-30-2019 06:48 AM
*67 as a prefix will mean you have to adjust all dial peers.
Why not simply copy the LD Route Patterns... put *67 in front of the 8 or 9 and restrict Line Presentations on anyone dialing *67(and normal LD Pattern)?
Cisco Voice Guy
Descubra e salve suas ideias favoritas. Volte para ver respostas de especialistas, passo a passo, tópicos recentes e muito mais.
Novo por aqui? Comece com estas dicas. Como usar a Comunidade Guia do novo membro
