05-12-2017 09:33 AM - edited 03-17-2019 10:19 AM
can I use non standart SIP port for SIP client connections on CUCM ?
SIP profile tcp+udp 5060
and example i want make SIP profile TCP+UDP on 7777 port (for SIP phone reistrations)
I need to register third party SIP phone with non default port.
I had tried to change the port number in the Phone security profile, but the phone was not registering.
With port 5060 everithing works fine.
05-12-2017 01:53 PM
Is there somewhere in the 3rd party device itself where you can manually set the port from 5060 to 7777? If you can set the port in the 3rd party device itself, I would think it should register. If there is no place in the device to manually set the port, then I would think you have to use the default port of 5060.
Bill
05-12-2017 11:36 PM
check call manager service parameters, you might be able to change it there, but I doubt that you can do it for clients only.
Please rate if useful
