Using a Loopback to register Voice GW to CallManager
rrobles007
Hello Cisco experts,
I had a question about how to use a loopback address as the IP address that is used for registering the GW to the CallManager.
Right now the GW uses the ip address of the LAN interface but that will be changing soon and the new LAN IP is not going to be reachable by the CallManager so I want to use a Loopback and give it the existing IP of the LAN interface (currently reachable from CM)
Can someone please help??
You are spot on hear.
You should always use a bound  loopback address when you have multiple ip addressed interfaces.
Add this to your config
mgcp bind media source interface loopback0
mgcp bind signal source interface loopback0
mgcp
Make sure you advertise the loopback via your BGP or OSPF and test that it has connectivity throughout your voip network as your CUCM, phones and other gateways will need 2 way comms for RTP streams etc. TTest this before you implement the config change.
Alex
Regards, Alex. Please rate useful posts.
rrobles007
Sorry.. additional detail.. this is an MGCP configuration.
vamer-laframet1-1394743#show run
Building configuration...
Current configuration : 3702 bytes
! Last configuration change at 17:20:04 GMT Wed Oct 12 2011 by admin
! NVRAM config last updated at 17:22:49 GMT Wed Oct 12 2011 by admin
version 12.4
service timestamps debug datetime msec localtime
service timestamps log datetime localtime
service password-encryption
hostname vamer-laframet1-1394743
boot-start-marker
boot-end-marker
logging buffered 4096 debugging
enable secret 5 $1$UoZ4$6c5p8qLCGSk9at0fhVp8Y/
aaa new-model
aaa session-id common
clock timezone GMT 0
clock calendar-valid
network-clock-participate wic 2
ip cef
no ip bootp server
no ip domain lookup
ip domain name virginam.com
isdn switch-type primary-ni
voice-card 0
no dspfarm
username GNOuser password 7 110D325C1634202406
username admin password 7 13061E010803
controller T1 0/2/0
framing esf
linecode b8zs
channel-group 0 timeslots 1-24
controller T1 0/2/1
framing esf
linecode b8zs
pri-group timeslots 1-24 service mgcp
ip ftp source-interface Loopback0
ip tftp source-interface Loopback0
interface GigabitEthernet0/0
ip address 172.19.4.4 255.255.255.0
duplex full
speed auto
interface GigabitEthernet0/1
ip address 10.16.0.42 255.255.255.252
duplex auto
speed auto
interface Serial0/2/0:0
ip address 10.14.0.42 255.255.255.252
fair-queue
interface Serial0/2/1:23
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
interface Serial0/3/0
no ip address
encapsulation frame-relay IETF
shutdown
no fair-queue
frame-relay lmi-type cisco
router ospf 1
log-adjacency-changes
redistribute bgp 65012 subnets
network 10.16.0.40 0.0.0.3 area 0
default-information originate
router bgp 65012
no synchronization
bgp router-id 10.14.0.42
bgp log-neighbor-changes
network 10.14.0.40 mask 255.255.255.252
network 10.17.4.0 mask 255.255.255.0
network 10.18.4.0 mask 255.255.255.0
network 10.19.4.0 mask 255.255.255.0
network 172.19.1.0 mask 255.255.255.0
network 172.19.4.0 mask 255.255.255.0
redistribute ospf 1
neighbor 10.14.0.41 remote-as 1803
no auto-summary
ip forward-protocol nd
ip as-path access-list 1 permit ^$
no ip http server
no ip http secure-server
control-plane
ccm-manager redundant-host 172.20.9.200
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server 172.20.9.200
ccm-manager config
mgcp
mgcp call-agent 172.20.9.201 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp profile default
privilege exec level 0 traceroute
privilege exec level 1 ping ip
privilege exec level 0 ping
privilege exec level 0 send
privilege exec level 0 show configuration
line con 0
exec-timeout 30 0
password 7 13013C4B0A2A2F0229
stopbits 1
line aux 0
exec-timeout 30 0
password 7 121D2E4E132D272C28
no exec
stopbits 1
line vty 0 4
exec-timeout 30 0
password 7 045F205F0E0767660B
transport input telnet
scheduler allocate 20000 1000
ntp clock-period 17180293
ntp source Loopback0
ntp update-calendar
ntp server 146.170.64.132 prefer
ntp server 146.170.124.133
end
mgcp
Alex
thank you very much!!! thats what i was leaning towards doing and you just confirmed.. thank you!!!!!!
There is a known defect in IOS that can cause the MGCP GW to register with another address then the one used in the bind statements. This only happens the first time the MGCP GW registers after the bind statements have been issued. The defect causes the GW to use the address of the interface closest to the CM. To check if this has happened look at the IP address that the GW have registered with in CM.
If this happens use the below commands.
no mgcp
no mgcp bind media source interface loopback0
no mgcp bind signal source interface loopback0
mgcp
Response Signature
