Highlighted
Beginner
Using a pause in speed dial in CUCM user options
Using the web interface of CUCM user options to setup some frequently dialed conference bridges in my user options but it will not accept a comma or period.
Message dialog box pops up and tells me it allows only numeric, +, *, or #
How would I configure a conference number of 18665551212 with a pin of 123456#?
Everyone's tags (3)
1 ACCEPTED SOLUTION
Highlighted
Hall of Fame Master
Right, you will need to
Right, you will need to upgrade to get this feature :-)
Let us know if you need anything else on this topic, otherwise you may mark the thread as answered.
Chris
4 REPLIES 4
Highlighted
Hall of Fame Cisco Employee
What version is this?
java
if this helps, please rate
Highlighted
Hall of Fame Master
What version of CUCM you are
What version of CUCM you are running as this feature was added in version 9 I believe. I tested on 10.5 system and was able to build speed dial with number such as "555,,,,,1234"
Highlighted
Beginner
From the about line I get:
Cisco Unified CM User Options
System version: 8.5.1.14051-1
Wow.. had no idea we were that far behind..  Oh well.. I am just a lowly data engineer in a big corporation.. I have no voice for the voice side of things lol
Thanks guys
Highlighted
Hall of Fame Master
Chris
