using BAT how to insert or create phone button templates
manjujunnur07
Beginner
Beginner
Hi ,
is there any procedure to add the phone button template using BAT tool .
1 ACCEPTED SOLUTION
OK, then the only way is to use the Export/Import BAT feature located under Bulk Administration --> Export/Import menu.
HTH, please rate all useful posts!
Chris
4 REPLIES 4
Chris Deren
Hall of Fame Master Hall of Fame Master
Hall of Fame Master
Are you asking about adding multiple phone button templates to CUCM or assigning them to phones?
If the first you could use the export/import feature of CUCM, if the second then you can simply add it to the phone via BAT and run phone update.
HTH,
Chris
Hi Chris ,
i want to add multiple phone button templates to CUCM
Chris
Thanks Chris
