using MRG of other site
techguy
Enthusiast
Enthusiast
I have 2 sites lets say, Site A is not having limited Media Resources andSite B is not using its resources at all (All are free)
Now is it possible that Site A could use Site B's MR. Both's Media resources are registered in CUCM.
3 REPLIES 3
David Hailey
Advisor
Advisor
Yes, just add the MRG to an MRGL that is assigned to the other site. Make sure you allow the necessary CODECs on the resources to be shared between sites. As a rule, I would prioritize the local resources first with failover to the remote site resources.
Hailey
Please rate helpful posts!
Sent from Cisco Technical Support Android App
Thanks for your confirmation.
I just want to know that what do you mean by your following statement
"Make sure you allow the necessary CODECs on the resources to be shared between sites"
Chris Deren
Hall of Fame Master Hall of Fame Master
Hall of Fame Master
Your region relationship between these sites in CUCM needs to be planned accordingly, i.e. if you are allowing G711 conferencing between sites for example.
Chris
