11-22-2010 01:34 AM - edited 03-16-2019 02:02 AM
My goal is to redirect all incomming calls on a specific DID to an AA which play a wav file while transferring the call to the receptionnist.
Our call control is a CallManager and our voice gateway have a CUE module.
I think the best way is to configure an AA script (using CUE Editor) which will check receptionnist availabilty and then make a blind transfer. During all the process, caller should ear a wav file.
Anybody have already done this or have some clues to help me ?
Thanks for your answer.
Best regards,
Nicolas.
11-22-2010 05:36 AM
I made some research and maybe it will be easier using TCL script.
Anybody have already use TCL script to handle queue on a voice gateway ?
11-22-2010 06:46 AM
The CUE AA will work for this but I don't have any guidance other than what you've already specified. Create a custom AA script in CUE and have it play the wav file why performing the transfer to the receptionist.
-Felipe
11-22-2010 08:02 AM
maybe I mess something but with the script I made (screenshot attached) the entire wav file will be read (about 1minute) before starting transfering to receptionist ?
For the moment I dit not manage to upload my script to test it (I think my version of CUE Editor is to recent for this old CUE 2.1)
11-23-2010 03:07 AM
Unfortunately I was right. The whole prompt is played before the call can be transfered ...
Does anyone have an idea to check receptionist availability during the prompt ? maybe with B-ACD script ...
Best regards,
Nicolas
