01-11-2014 11:37 AM - edited 03-16-2019 09:12 PM
I have an older Cisco 2921 ISR that was recently upgraded to the following software versions:
IOS: 15.1(4)M7
CME: 8.6
CUE: 7.0.6
However, I don't think the CME files on the flash were appropriately upgraded. Just the IOS version.
Where would I find the appropriate download for all the ringtones, IP phone loads, etc. and how to properly import them into flash so I know that I have the proper support files to go along with this most updated version of the CME IOS version?
01-11-2014 12:34 PM
Installing Cisco Unified CME Software
To install Cisco Unified CME in flash memory, perform the following steps.
SUMMARY STEPS
1. Go to Software Download site.
2. Download archive.
3. Extract files to be downloaded.
4. Use the copy or archive tar command to copy file to flash memory.
5. Use the show flash: command to list files in flash memory.
DETAILED STEPS
Step 1 Go to http://www.cisco.com/pcgi-bin/tablebuild.pl/ip-key.
Step 2 Select the file to download.
Step 3 Download zip file to tftp server.
Step 4 Use the zip program to extract the file to be installed, then:
a. If the file is an individual file, use the copy command to copy the files to router flash:
Router# copy tftp://x.x.x.x/P00307020300.sbn flash:
b. If the file is a tar file, use the archive tar command to extract the files to flash memory.
Router# archive tar /xtract source-url flash:/file-url
Step 5 Verify the installation. Use the show flash: command to list the files installed in in flash memory.
Router# show flash:
31 128996 Sep 19 2005 12:19:02 -07:00 P00307020300.bin
32 461 Sep 19 2005 12:19:02 -07:00 P00307020300.loads
33 681290 Sep 19 2005 12:19:04 -07:00 P00307020300.sb2
34 129400 Sep 19 2005 12:19:04 -07:00 P00307020300.sbn
Step 6 Use the archive tar /create command to create a backup tar file of all the files stored in flash. You can create a tar file that includes all files in a directory or a list of up to four files from a directory.
For example, the following command creates a tar file of the three files listed:
archive tar /create flash:abctestlist.tar flash:orig1 sample1.txt sample2.txt sample3.txt
The following command creates a tar file of all the files in the directory:
archive tar /create flash:abctest1.tar flash:orig1
The following command creates a tar file to backup the flash files to a USB card, on supported platforms:
archive tar /create usbflash1:abctest1.tar flash:orig1
Check out:
Installing and Upgrading Cisco Unified CME Software
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeinstl.html
Basically the easiest way is to extract the .zip file, and create a .tar archive and use the archive tar /xtract command in CME to extract them from a TFTP server to flash.
Br,
Nadeem
Please rate all useful post.
01-11-2014 01:21 PM
I think I understand. One other question.
In order to make sure that phones can properly register, apart from having the correct phone load config under telephony-service (i.e. load 7961 xxxsadfsdf.loads) do ALL the files related to that phone's phone load need to be specifically defined in the tftp configuration?
For example all my phone loads and files are under flash:/phones
So I should have a config line that looks like tftp://flash/phones/dsafsd.bin, tftp://flash:/phonessdfsdf.sbn, etc. for all file related to that specific model of phone, correct?
01-12-2014 05:32 AM
Correct,as an example
The following example shows how to configure Cisco Unified CME so that the Cisco Unified IP Phone 7911 can download the appropriate SCCP firmware from flash memory:
Router(config)# telephony-service
Router(config-telephony)#load 7911 SCCP11.7-2-1-0S
The following example shows a list of phone firmware files that are installed in flash memory for the Cisco Unified IP Phone 7911:
tftp-server flash:SCCP11.7-2-1-0S.loads
tftp-server flash:term06.default.loads
tftp-server flash:term11.default.loads
tftp-server flash:cvm11.7-2-0-66.sbn
tftp-server flash:jar11.7-2-0-66.sbn
tftp-server flash:dsp11.1-0-0-73.sbn
tftp-server flash:apps11.1-0-0-72.sbn
tftp-server flash:cnu11.3-0-0-81.sbn
Br,
Nadeem
