utils command on CUCM
yamaguchi4
Hi.
I have CUCM 9.1.  I needs to use "utils" command on CLI but it says Unrecognized command. How can I make the command available? Thank you.
You will have to upgrade IOS, or you can try fast track to see if it works.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/feature/phone_feature/phone_feature_support_guide.html
Once the new SIP phone model is configured using the fast-track configuration approach, the new phone model can be provisioned using the existing voice register pool configuration option as shown below:
voice register pool 1
type 7821
id mac D824.BD27.9EAC
voice register global
mode cme
load 7821 sipCisco IP Phone 7800 Series.10-1-1SR1-4.loads
Note: Use the "show voice register pool-type <new-phone-model>" or "show voice register pool-type all" command to display the properties of a new phone model.
CME1# sh voice register pool type 7821
FastTrack Phone Model : 7821
Pooltype(index) representing the phone model : 48
Reference pooltype to inherit the properties from : 6921
Number of lines supported : 2 (inherited from 6921)
Number of addon modules supported : 0 (inherited from 6921)
Default session transport : UDP (inherited from 6921)
Description(helpstring) : Cisco IP Phone 7821
Phone supports GSM : NO (inherited from 6921)
Phone supports Telnet acess : NO (inherited from 6921)
Phone supports firmware download from CME : YES (inherited from 6921)
Phone specific XML tags :
maxNumCalls12/maxNumCalls (inherited from 6921)
busyTrigger12/busyTrigger (inherited from 6921)
Phone family : RTL_PHONES
Pool ID IP Address Ln DN Number State
6 D824.BD27.9EAC 9.44.29.44 1 6 4080$ REGISTERED
(Rate if it helps)
JB
19 Replies 19
Jitender Bhandari
You don't have to enable "utils" command, it is enabled by default.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/cli_ref/9_0_1/CUCM_BK_C3A58B83_00_cucm-cli-reference-guide-90/CUCM_BK_C3A58B83_00_cucm-cli-reference-guide-90_chapter_01001.html?bookSearch=true
attach the error that you are getting.
Also attach the output of "Show hardware" and "Show status"
(Rate if it helps)
JB
Hi. Thank you. Here it is.
voice#show hardware
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.2(4)M4, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Thu 20-Jun-13 13:06 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
dsmn-v001 uptime is 49 weeks, 3 days, 16 hours, 5 minutes
System restarted at 17:12:14 Dubai Sun Aug 7 2016
System image file is "flash0:c2900-universalk9-mz.SPA.152-4.M4.bin"
Last reload type: Normal Reload
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2921/K9 (revision 1.0) with 475136K/49152K bytes of memory.
Processor board ID FGL17321083
4 Gigabit Ethernet interfaces
2 terminal lines
12 Voice FXO interfaces
1 Internal Services Module (ISM) with Services Ready Engine (SRE)
Cisco Unity Express 8.0.5 in slot/sub-slot 0/0
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
999936K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device# PID SN
*0 CISCO2921/K9
Technology Package License Information for Module:'c2900'
Technology Technology-package Technology-package
Current Type Next reboot
ipbase ipbasek9 Permanent ipbasek9
security None None None
uc uck9 Permanent uck9
data None None None
voice#show status
% Invalid input detected at '^' marker.
voice#utils service ?
% Unrecognized command
voice#utils
You are not using CUCM, you can not use "utils" command on IOS.
can you do "Show telephony" and post it here.
(Rate if it helps)
JB
Oh.. Thank you. Here is result.
voice#show telephony
CONFIG (Version=9.1)
Version 9.1
Max phoneload sccp version 17
Max dspfarm sccp version 18
Cisco Unified Communications Manager Express
For on-line documentation please see:
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/tsd_products_support_series_home.html
protocol mode default
ip source-address 10.73.224.189 port 2000
ip qos dscp:
ef (the MS 6 bits, 46, in ToS, 0xB8) for media
cs3 (the MS 6 bits, 24, in ToS, 0x60) for signal
af41 (the MS 6 bits, 34, in ToS, 0x88) for video
default (the MS 6 bits, 0, in ToS, 0x0) for serviceno service directed-pickup
no auto-reg-ephone
load 7911 SCCP11.9-2-1S
load 7962 SCCP42.9-2-1S
max-ephones 75
max-dn 150
max-conferences 8 gain -6
dspfarm units 3
dspfarm transcode sessions 1
dspfarm 1 CFBDSP1
dspfarm 2
dspfarm 3
conference hardware
conference transfer-pattern
privacy
no privacy-on-hold
hunt-group report delay 1 hours
hunt-group logout DND
max-redirect 10
cnf-file location: flash:
cnf-file option: PER-PHONE-TYPE
network-locale[0] US (This is the default network locale for this box)
network-locale[1] US
network-locale[2] US
network-locale[3] US
network-locale[4] US
user-locale[0] US (This is the default user locale for this box)
user-locale[1] US
user-locale[2] US
user-locale[3] US
user-locale[4] US
srst mode auto-provision is OFF
srst ephone template is 0
srst dn template is 0
srst dn line-mode single
moh poppoya3.au
time-format 12
date-format dd-mm-yy
timezone 35 Arabian Standard Time
call-forward pattern .T
transfer-pattern .T
night-service code *6100
night-service day Sun 16:31 07:29
night-service day Mon 16:31 07:29
night-service day Tue 16:31 07:29
night-service day Wed 16:31 07:29
night-service day Thu 16:31 07:29
night-service day Fri 07:30 07:29
night-service day Sat 07:30 07:29
keepalive 30 auxiliary 30
timeout interdigit 3
timeout busy 10
timeout ringing 180
timeout transfer-recall 0
timeout ringin-callerid 8
timeout night-service-bell 12
caller-id name-only: enable
web admin system name cisco password cisco
web admin customer name admin password admin
edit DN through Web: enabled.
edit TIME through web: enabled.
background save interval 10 minutes
Log (table parameters):
max-size: 150
retain-timer: 15
create cnf-files version-stamp 7960 Sep 13 2015 13:41:11
transfer-system full-consult
transfer-digit-collect new-call
login timeout 60
multicast moh 239.1.1.1 port 16384
local directory service: enabled.
Extension-assigner tag-type ephone-tag.
So you are using "Cisco Unified Communications Manager Express" is it says and below is command line reference guide for "Cisco Unified Communications Manager Express"
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/command/reference/cme_cr.html
what are you trying to achieve?
(Rate if it helps)
JB
I understand. Thank you. What I want to do is to install device pack by CLI. I downloaded it but does not know how to install.
You cannot install device pack on CME. what are you trying to achieve?
JB
We want to add new phone. Model is 7821. I tried to register but I cannot see 7821 for type of ephone.
ephone 20
type xxxx  < No 7821..
type 7821
mode cme
(Rate if it helps)
JB
Looks like you would not be able to use FAST Track as it was introduced in CME 10.X
https://supportforums.cisco.com/document/12210701/fast-track-support-sip-phones
You will have to upgrade IOS.see below for help
https://supportforums.cisco.com/document/98421/how-upgrade-or-downgrade-ios-isr-or-similar-router
(Rate if it helps)
JB
OK. I do first it and check.
Whichever CME version you choose make sure you are aware of memory\platform requirement for it.
Supported Platforms and Memory Specifications: SIP IP Phones*
Cisco Platform
Maximum Total IP Phones1
Maximum SIP IP Phones
Maximum Total Virtual Ports (dns)
RecommendedDRAM
Recommended Flash Memory
Cisco 881V
1 GB
256
Cisco IAD 2430
not supported
not supported
not supported
not supported
not supported
Cisco 1861E
not supported
not supported
not supported
not supported
not supported
Cisco 2801
not supported
not supported
not supported
not supported
not supported
Cisco 2811
not supported
not supported
not supported
not supported
not supported
Cisco 2821
not supported
not supported
not supported
not supported
not supported
Cisco 2851
not supported
not supported
not supported
not supported
not supported
Cisco 2901
35
35
200
1 GB
256
Cisco 2911
50
50
300
1 GB
256
Cisco 2921
100
100
400
1 GB
256
Cisco 2951
150
150
500
1 GB
256
Cisco 3825
not supported
not supported
not supported
not supported
not supported
Cisco 3845
not supported
not supported
not supported
not supported
not supported
Cisco 3925
250
250
600
1 GB
256
Cisco 3925E
400
400
1100
1 GB
256
Cisco 3945
350
350
900
1 GB
256
Cisco 3945E
450
450
1200
1 GB
256
Cisco ISR 4321
50
50
200
4 GB
4 GB
Cisco ISR 4331
100
100
400
4 GB
4 GB
Cisco ISR 4351
250
250
600
4 GB
4 GB
Cisco ISR 4431
350
350
900
4 GB
8 GB
Cisco ISR 4451
450
450
1200
4 GB
8 GB
* These memory recommendations and maximum numbers of IP phones are for common Cisco Unified CME configurations only. Systems with large numbers of phones and complex configurations may not work on all platforms and can require additional memory or a higher performance platform.
http://www.cisco.com/c/en/us/support/unified-communications/unified-communications-manager-express/products-device-support-tables-list.html
(Rate if it helps)
JB
OK. Thanks. Let me upgrade and see what happen on phone type. Then I update you.
Have you got this working?
JB
