354
homelandsecureit
Beginner
Valcom 2001a on UC540
I have a UC540 setup using the CCA. i also have a Valcom 2001a for overhead paging. Can someone please tell me how to config this in the CCA? i have found post about the UCM but that does not help me.
2 REPLIES 2
testeven
You can refer to this document, it might help:
https://supportforums.cisco.com/docs/DOC-9776
Tere.
If you find this post helpful, please rate!
Regards, Tere. If you find this post helpful, please rate! :)
Thanks for the response, however, this is a new system being installed with NO door opener. what i need is a step by step on how to configure the overhead paging system in the CCA for use on the UC540.
Create
Recognize Your Peers
Content for Community-Ad
