02-13-2017 10:37 AM - edited 03-17-2019 09:30 AM
Hi All,
We have VCS-E running version X8.X. We are facing strange issue.
Below is the interface configuration
LAN-1 : 10.2.16.23/26 GW: 10.2.16.1
LAN-2 : 10.2.16.73/26 GW : 10.2.16.65
When We reboot the VCS-E, LAN-2 interface's default gateway changes to 10.2.16.1 from 10.2.16.65 and LAN-1 interface's default gateway changes to 10.2.16.65 and nothing works. Not even CLI or GUI access.
We have to reboot the server and run setup wizard from console and need to change LAN-1 interface's default gateway to 10.2.16.1 to get GUI access back.
Once we get GUI access, When we chage LAN-2 default gateway to 10.2.16.65 and reboot VCS-E, again same thing happens.
Can someone please help.
Note: Setup was running smooth since last week.
Solved! Go to Solution.
02-16-2017 08:56 PM
Hi There,
It looks like your default gateway IP address is out of range of the subnet assigned to LAN#2. See screenshot below.
Usually we set the default gateway of the VCS Expressway to that of LAN#2 (in your case this would be 10.2.16.65). If the VCS Expressway needs to access resources on LAN#1, you can write a static route for this purpose.
If you set your default gateway to 10.2.16.65, the configuration should not be lost on a restart because it will now be valid.
Does that help?
02-13-2017 08:59 PM
Can you clarify what you mean by "default gateway" for LAN1 and LAN2?
The VCS only has the capability of having a single default gateway, are you using a combination of the IPv4 Gateway and static routes?
02-15-2017 04:02 AM
02-16-2017 08:56 PM
Hi There,
Does that help?
02-16-2017 10:09 PM
I totally agree, Default gateway should be 10.2.16.65. But when I change the default gateway from 10.2.16.1 to 10.2.16.65, i am loosing even access of the VCS-E. In order to get back access I have to change default gateway to 10.2.16.1 from console.
03-11-2017 05:12 PM
Were you able to get this sorted out?
If not, You need to make sure that the VCS-E is able to route return traffic back to your management PC.
If your management PC is on the internal network but is not in the same subnet as LAN#1 of the VCS-E then you can write a static route on the VCS-E to send the traffic back to your management PC subnet from the LAN#1 interface (System > Network Interfaces > Static Routes).
03-11-2017 11:39 PM
01-27-2021 03:55 PM - edited 01-27-2021 03:55 PM
hello Team,
I am also trying to setup expressways now.
I want to setup clustering of expressway E's which I believe will be over LAN 1 and at the same time use external DNS for ExpresswayE to contact external IdP.
My gateway is currently set to LAN1 default gateway, I don't want to route external DNS traffic to LAN1. Do i need to use Static Route for DNS towards LAN2 gateway? Kindly advise.
01-27-2021 10:20 PM - edited 01-27-2021 10:22 PM
As this is an old and marked as answered post I recommend you to create your own post with your question. Especially as your question is off topic to the OP. You would likely get more help in this way.
