607
Highlighted
VIP Advisor
VCS-expressway MRA combined with business to business calls
Looking for some insights on whether it is possible to add MRA to an existing VCS-e/VCS-C deployment that currently functions for URI business to business calls, across the internet.
The currently deployment is fully functional (X8.5.1), just want to know if it is not mutually exclusive to add MRA to the existing deployment, or if I need to spin up a new pair of VCS's. The Cisco SRND mentions the two deployments/functionalities, but mentions nothing of combining business-to-business with Jabber MRA on a single VCS-e Pair.
input welcome
Please remember to rate useful posts, by clicking on the stars below.
1 ACCEPTED SOLUTION
Highlighted
Beginner
You can have B2B and MRA on the same VCS pair.
The MRA Deployment Guide makes a note about B2B – check page 42
http://www.cisco.com/c/dam/en/us/td/docs/telepresence/infrastructure/vcs/config_guide/X8-6/Mobile-Remote-Access-via-VCS-Deployment-Guide-X8-6.pdf
"you may still configure a SIP trunk if required (for example, to enable B2B callers or endpoints registered to VCS to call endpoints registered to Unified CM)."
-Atul
4 REPLIES 4
Highlighted
Beginner
-Atul
Highlighted
thanks for that, the SIP trunk I don't need to worry about as that is already in place.
I think the mutual exclusiveness is with MRA and Jabber guest, that can't run on the same VCS pair.  (on the VCS under unified communication you can choose either MRA or Jabber Guest, NOT BOTH).
cheers
Highlighted
And in addition to this, when combining MRA and B2B, does that mean 1 traversal zone needs to exist, configured with the type  "unified communications"?  as I currently have a traversal zone with Type "traversal Client"?
Highlighted
Yes, you need to add a "Unified Communications traversal" zone on both expressways. Since you already have B2B deployed, you'll need to be careful with ports. For example, CUCM can't be listening on the same port for SIP trunk and MRA line side (well, it can, but MRA phones won't register). Same with SIP communications between Expressway-C and E.
