Verify DTMF digits are sent to PSTN
blive56133
Level 2
Level 2
Hi.
How can I see if and which DTMF numbers are being sent to PSTN?
I have CUCM connected to CUBE via SIP trunk. From CUBE to PSTN provider we also use SIP. In most cases when we use DTMF everything is ok. But when I call certain numbers, DTMF doesn't work. How can I check that I am actualy sending digits outside of my network?
I tried using these commands but the output is simply too extensive especially because I don't know what I'm looking for.
debug voip ccapi inout
debug ccsip all
debug voip rtp
So, let's say I use 131313 as dtmf digits. How will I see it in debug (and which debug should I use)?
12 Replies 12
Manish Gogna
Please check the following
https://supportforums.cisco.com/blog/154706
http://www.cisco.com/c/en/us/td/docs/ios/voice/cube/configuration/guide/vb_book/vb_book/vb_1380.html
Manish
Thanks for guides but it doesn't really help with troubleshooting.
I use RFC2833 (see it in debug). But how do I see dtmf digits that are being sent, only via Wireshark?
Yes, inband dtmf will be visible in Wireshark.
Manish
is it visible in any of the debug commands?
As I said in my earlier post. Use debug voip rtp session named-event.
It depends on which DTMF relay method used. If you are using SIP out-of-band (NOTIFY, INFO, KPML), in this case you "debug ccsip mess" should show you the digits. In case you are using RTP-NTE, you can use "debug voip rtp session named-event" - See more at: https://supportforums.cisco.com/discussion/12545781/verify-dtmf-digits-are-sent-pstn#sthash.yoLDPRso.dpuf
I wasn't sure which one I am using. But I tried both of the debugs you mentioned.
For "debug voip rtp session named-event" I didn't get any output in the debug (so it seems I don't use rtp-nte...)
For debug 'ccsip messages' I got output but I can't find dtmf digits I dialed - in 1.txt digits were 151515 and in 2.txt digits were 88888888? In which part of debug can I see this digits?
RTP-NTE is inband DTMF, where DTMF sent using the RTP stream (media). Try checking or collecting the packet capture .
this need to decode further and sample to find out the digit pressed.
Feb 06 10:03:00.910:          Pt:101    Evt:5       Pkt:04 00 00  <Snd>>>
Feb 06 10:03:00.910:          Pt:101    Evt:5       Pkt:04 01 90  <Snd>>>
Feb 06 10:03:00.910:          Pt:101    Evt:5       Pkt:84 03 20  <Snd>>>
Br, Nadeem Please rate all useful post.
I'm sorry but I don't understand. Can I collect and view digits via debug command or not? Or I MUST use wireshark?
ideally it should show up in the debug if not then  you can collect the wireshark capture on the GW to see digit in the RTP stream.
Br,
Nadeem
the link you mention is for this post...
Nadeem Ahmed
Yes it depends what kind of dtmf relay method you are using in your environment. If it OOB it can be very much feasible and viewable in the traces/logs in case of in-band you need to PCM capture for that.
Br,
Nadeem
