Highlighted
Frequent Contributor
Version 12
I am setting up collaboration version 12 in my lab. I have CUCM 12 and CUC 12 (seems now 2 different iso files)
But till now I don't see IM&P version 12. Is this not released yet, or did something change?
Any idea?
JH
19 REPLIES 19
Highlighted
VIP Advisor
Starting from 11.5 IMP and CUCM are in the same ISO
Highlighted
Don't think so, I have installed many 11.5 installations and IMP has it's own iso and ova file
CUCM and CUC 'share' and iso file, but with different ova files
Maybe you mean from version 12?
Jan
Highlighted
No, that's definitely wrong, on 11.5 CUCM/CUC shared the ISO, and IM&P had a separate ISO
On 12.x, now you have one ISO for each one of those products, I show how you use a different ISO on the upgrade to 12.x videos I created.
Supported Versions
The following software versions apply to Release 12.0(1):
  • Cisco Unified Communications Manager 12.0.1.10000-10
    IM and Presence Service 12.0.1.10000-12
java
if this helps, please rate
Highlighted
My bad ... Big sorry for my silly answer. I shouldnt be posting while
watching new year show here in dubai :(
My apologies.. stepping away for a while till I recover :)
Highlighted
Hello Jaime
I can't find the IM&P version 12 for download, only the recovery iso
Is IM&P 12 released?
Jan
Highlighted
Hall of Fame Cisco Employee
For some reason the BU decided that they would NOT post the base image for 12.x and that you'd have to forcefully use PUT to get the images. From what I know, now you get the CUCM and IMP images in the CUCM 12.x media kit.
java
Highlighted
Hello Jaime
OK, clear, I shall check with Cisco in my country
Jan
Highlighted
Were you ever able to obtain the base ISO for IM&P 12? I am in the same boat and still do not see in software download or in PUT.
Highlighted
We are a Cisco partner, and Cisco in my country published the image for me
Highlighted
Hi Jaime,
Cisco partner here.  We have a customer who subscribed to a Cisco Collaboration Flex Plan (first time selling Flex) and they can't access PUT with the contract numbers or the subscription ID's.  The error I get in PUT is "110 - The products covered under this service contract (XXXXXXXX) do not currently have any available major upgrade releases or do not require upgrades to be ordered through the Product Upgrade Tool."
I believe the order modification will get them the 12.x licenses but how are they supposed to gain access to the 12.x Base images?
Highlighted
Hi Please check section 5 and 6 of this guide https://salesconnect.cisco.com/open.html?c=c770fdfb-e359-41c8-a028-272d1cbf587a
ashish
Response Signature
Highlighted
Hi Jaime
I have the same problem. Could you get the ISO upgrade image for IM & Presense 12.X?
@j.huizinga wrote:
Hello Jaime
Jan
Highlighted
Yes, but I have direct access to the images, any partner or customer needs to use PUT to order the CUCM media kit which will have CUCM, IM&P and PCD.
java
Highlighted
##- Gracias Jaime,
Pero por qué la Imagen de Presence de Upgrade no aparece y las de CUCM y Unity Connection si, me parece que es más tramite, adicional no es una nueva instalación, es un proceso de upgrade.
Content for Community-Ad
