VG 224 Slot0
Dan Lynch
I was upgrading the IOS and  got a head of myself and didn't name the file I loaded into slot0. Does anyone know how to remove an unnamed file in slot0?
Hi Dan,
I suppose the name of file is slot0 itself.
You have got two options .
Option 1:
You can try erasing .
use the command erase slot0:slot0 and then, run the command show slot0: to check whether it has been deleted or not.
Option 2:
other way round, you can download the existing vg224-i6k9s-mz.151-4.M10.bin and then, erase slot0: completely .
Now, again run show slot0:
The available total space should be 28951136x2. During this , do not switch off VG224. Now again upload , vg224-i6k9s-mz.151-4.M10.bin  and then, finally desired one.
regds,
aman
Aman Soi
Hi Dan,
can u share the output of show slot0: or show flash from vg224?
Also, share show version.
regds,
aman
CORBAYVG01#sh slot0
-#- --length-- -----date/time------ path
1     28951136 Mar 24 2016 08:24:44 +00:00 vg224-i6k9s-mz.151-4.M10.bin
2     28951136 Mar 24 2016 08:14:34 +00:00 slot0
Cisco IOS Software, vg224 Software (vg224-I6S-M), Version 15.1(4)M10, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Tue 24-Mar-15 15:15 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T7, RELEASE SOFTWARE (fc1)
CORBAYVG01 uptime is 3 weeks, 3 days, 19 hours, 35 minutes
System returned to ROM by reload at 07:24:20 UTC Thu Mar 3 2016
System restarted at 07:25:44 UTC Thu Mar 3 2016
System image file is "slot0:vg224-i6s-mz.151-4.M10.bin"
Last reload type: Normal Reload
Cisco VG224 (R527x) processor (revision 4.1) with 250880K/11264K bytes of memory.
Processor board ID FTX1746AL0T
R527x CPU at 225MHz, Implementation 40, Rev 3.1
1 On-Board Twenty-Four FXS Analog Voice Module V2.1
2 FastEthernet interfaces
DRAM configuration is 64 bits wide with parity disabled.
63K bytes of non-volatile configuration memory.
System fpga version is 250027
System readonly fpga version is 250027
Option for system fpga is 'system'.
63808K bytes of ATA Slot0 CompactFlash (Read/Write)
Hi Dan,
Option 1:
Option 2:
regds,
aman
Thank you sir I had to deltete slot0 then copy the new file all is good now
