01-26-2012 12:51 AM - edited 03-16-2019 09:13 AM
Hi guys,
The VG 224 in SCCP is support whit cucm 8.8 ?
Thanks for your help.
01-26-2012 12:57 AM
There is no CUCM 8.8 but if you meant CME 8.8, yes VG224 is supported as usual with SCCP.
Pls refer the CME Compatibility Matrix & Datasheets available on CCO.
Pls rate the post if it helps.
GP.
01-26-2012 01:33 AM
Yes, the version is CUCME 8.8. What IOS version do you recomend?
Thanks.
01-26-2012 01:42 AM
As mentioned in the CUCME 8.8 compatibility matrix, To get a list of Cisco IOS software releases that support Cisco Unified CME 8.8, go to Feature Navigator.
GP
