05-25-2013 01:10 AM - edited 03-16-2019 05:30 PM
we have a CUCM that uses a Cisco 2951 with IOS c2951-universalk9-mz.SPA.153-1.T.bin as a Voice Gateway (in SIP).
We have noticed on the router (by the command "debug isdn q921") that the messages in attachment appears continuously.
Here's a sample:
May 25 2013 09:41:08 LEGALE: ISDN Se0/0/0:15 Q921: User RX <- REJ sapi=0 tei=0 nr=33
May 25 2013 09:41:08 LEGALE: ISDN Se0/0/0:15 Q921: S7_REJ_RNR_RR: REJ received Nr 33 VA = 33, VS = 33
May 25 2013 09:41:09 LEGALE: ISDN Se0/0/0:15 Q921: User RX <- REJ sapi=0 tei=0 nr=33
May 25 2013 09:41:09 LEGALE: ISDN Se0/0/0:15 Q921: S7_REJ_RNR_RR: REJ received Nr 33 VA = 33, VS = 33
Is it an issue? If yes, how can it be solved?
Furthermore, can it be the cause of a poor quality on some calls that users complain?
TIA and regards.
05-25-2013 06:05 AM
Post "show controllers E1".
05-25-2013 10:02 AM
E1 0/0/0 is up.
Applique type is Channelized E1 - balanced
Description: ISDN PRI N.1 - Primary PRI PSTN *********
No alarms detected.
alarm-trigger is not set
Version info FPGA Rev: 08121917, FPGA Type: PRK1
Framing is CRC4, Line Code is HDB3, Clock Source is Line.
International Bit: 1, National Bits: 11111
Data in current interval (91 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Total Data (last 69 15 minute intervals):
17 Line Code Violations, 0 Path Code Violations,
0 Slip Secs, 1 Fr Loss Secs, 1 Line Err Secs, 0 Degraded Mins,
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 1 Unavail Secs
05-25-2013 10:39 AM
No errors. You can check serial 0/0/0:15, but likely no errors there either, so these REJs are a bit strange.
05-26-2013 01:42 AM
Serial0/0/0:15 is up, line protocol is up (spoofing)
Hardware is DSX1
Description: description ISDN PRI TO PSTN *********
MTU 1500 bytes, BW 64 Kbit/sec, DLY 20000 usec,
Encapsulation HDLC, crc 16, loopback not set
Keepalive set (10 sec)
Last input 00:00:00, output 00:00:06, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
249314 packets input, 1001404 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
1 input errors, 1 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
6592 packets output, 30577 bytes, 0 underruns
0 output errors, 0 collisions, 4 interface resets
0 unknown protocol drops
1 carrier transitions
