06-03-2021 12:40 PM
I just received a VG-310 voice gateway and when I try to configure it, it will not accept any MGCP or CCM-MANAGER commands. When I run the show ver command, instead of listing 24 Voice FXS interfaces, it lists 1 VPN Module. I'm guessing this is part of the problem but do I have to replace actual hardware or is this a software / licensing issue?
Dale Shew
Solved! Go to Solution.
06-03-2021 03:01 PM
06-03-2021 12:51 PM
This sounds quite odd. What do you get if you issue show inventory on the system?
06-03-2021 12:58 PM
Hi Roger,
I get the following. I compared it to one of our in use gateways and it looks like it's missing the onboard 24 FXS voice interface.
Router>en
Router#show inventory
NAME: "VG310", DESCR: "VG310 chassis, Hw Serial#: FJC25071CYC, Hw Revision: 1.0"
PID: VG310 , VID: V01 , SN: FJC25071CYC
NAME: "PVDM3 DSP DIMM with 64 Channels on Slot 0 SubSlot 4", DESCR: "PVDM3 DSP D IMM with 64 Channels"
PID: PVDM3-64 , VID: V01 , SN: FOC24434AX8
NAME: "VG3X0 AC Power Supply", DESCR: "VG3X0 AC Power Supply"
PID: PWR-VG3X0-AC , VID: , SN:
Thanks for your help.
06-03-2021 03:01 PM
I would RMA that VG. Something is not correct with it.
06-03-2021 08:41 PM
Try to upgrade the VG iOS and see if it makes any change. if not, do RMA as @Roger Kallberg mentioned.
06-10-2021 01:24 PM - edited 06-10-2021 01:26 PM
06-10-2021 02:02 PM
Thanks for sharing. That’s very interesting and good information. Never seen this on any of all the VG3x0 we have.
06-10-2021 02:06 PM
Thanks. It was a first for us too.
