07-31-2015 10:15 PM - edited 03-17-2019 03:50 AM
I've been asked to do some research in to installing a Cisco VG 310. I wanted to see if anyone on the support forums have installed one before. I did some poking around, and configured a mock one in my home lab. It looks like its really just a basic voice gateway (router) with a ton of FXS ports. It looks like its best to just set it up as an MGCP gateway, and then configure your ports as you would any other FXS port in CUCM. Is that correct, or am I missing something?
Solved! Go to Solution.
07-31-2015 11:04 PM
Hi John
As far as I know, the Supplementary Services are much better served with the SCCP in VG3XX or VG2XX GWs.
So, in essence, it will be best if you can configured the GW in SCCP mode
http://www.cisco.com/c/en/us/products/collateral/unified-communications/vg-series-gateways/product_data_sheet09186a00801d87f6.html
07-31-2015 11:05 PM
Yes its got lot of fxs ports but it does support TDM and other protocols as well apart from MGCP, Refer:
Protocols Supported
The voice gateways support the following protocols:
● SCCP
● H.323v4
● MGCP
● SIP
● Real-Time Transport Protocol (RTP)
● Secure Real-Time Transport Protocol (SRTP)
● Trivial File Transfer Protocol (TFTP)
● HTTP server
● SNMP
● Telnet
● Dynamic Host Configuration Protocol (DHCP)
● Domain Name System (DNS)
● Cisco Unified Communications Manager or Cisco Unified Communications Manager Express redundancy support using Hot Standby Router Protocol (HSRP)
● Call survivability: MGCP failover to an H.323 connection to the SRST router
● Cisco Fax Relay, T.38 fax relay, and modem pass-through
● Coder/decoder (codec) support, G.711, and G.729a
● RADIUS and TACACS+ for Telnet and authorization
Also refer to technical specifications.
Also Refer here: http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/10_0_1/ccmsys/CUCM_BK_SE5FCFB6_00_cucm-system-guide-100/CUCM_BK_SE5FCFB6_00_cucm-system-guide-100_chapter_0100110.html#CUCM_RF_V83D221A_00
Cisco VG310 | MGCP | T1/CAS/PRI E1/PRI | FXS/FXO/BRI | |
SCCP | FXS/BRI | |||
H.323 and SIP | T1/CAS/PRI E1/PRI | FXS/FXO/BRI |
Refer to this post as well someone asked this couple of days ago:
https://supportforums.cisco.com/discussion/12561676/using-vg310-voice-router-wpri
-Terry
Please rate all helpful posts
07-31-2015 11:04 PM
Hi John
07-31-2015 11:14 PM
Wilson looks like we are replying to the questions at same time :)
-Terry
07-31-2015 11:18 PM
Ha ha, that was a nice co-incidence :-)
regards
08-02-2015 08:57 PM
Thanks for the help guys. This is all good info.
08-06-2015 11:20 AM
Just wanted to follow up. I installed the VG310 at a client site yesterday. It was pretty seamless. I did a "sho int g0/0" to get the mac address, and added it to CUCM with a SCCP integration. Once adding a couple commands at the interface, and adding the interface to CUCM it came right up. It was much easier than I anticipated, and worked well. I was able to get a 10 page fax in without any issue, and the client uses SIP trunks.
08-06-2015 12:02 PM
Glad that we were able to help
08-09-2015 05:10 PM
Good one John - thanks for the update! (+5)
-Terry
07-31-2015 11:05 PM
Protocols Supported
● SCCP
● H.323v4
● MGCP
● SIP
● HTTP server
● SNMP
● Telnet
-Terry
