03-02-2021 07:35 AM
I'm trying to register VG-450 secure SCCP but i get on the CUCM rejected.
I've already sign the VG on the Root CA and upload it to the VG, I didn't upload it to the CUCM because they have the same Root certificate.
I have the appropriate license for secure so its not a license problem.
Thanks for helping.
Solved! Go to Solution.
03-03-2021 11:02 PM
Hi everyone,
Thanks for replying, the problem has been solved.
At the start I did revocation check none, I changed the none and its worked fine.
03-02-2021 08:27 AM
Pretty sure you need to load it as a callmanager-trust even with the same root CA being used.
I have multiple docs that say to do this.
Below is one example.
I assume restarting the callmanager service will be a major service impact for you and that is why you are hesitating?
If so I recommend engaging tac on that question for the completed answer on why it is needed for the cert exchange.
03-02-2021 05:41 PM - edited 03-02-2021 05:42 PM
Have you configured secure mode configurations on gateway and configured all required configurations ?your CUCM is it in Mixed mode ?. Since its from the same root CA, I don't see a need to upload it to CUCM. The guides use self-signed which should be uploaded to the CUCM.
03-03-2021 11:02 PM
Hi everyone,
03-04-2021 06:12 AM
Great and thanks for the confirmation on the gateway certs not needing to be manually uploaded. I do agree they shouldn't need to be.
