VG202 configuration automatically pushed from CUCM
cvanitterbeeck
Hi all,
I'm busy configuring some VG202 but it seems that at every apply config or reset, that some parameters are coming from the CUCM and this is making my configuration fail (with fax).
Here are the points that are automatically pushed
voice-port 0/0
 cptone GB
 timeouts initial 60
 timeouts interdigit 60
 timeouts ringing infinity
Is it possible to avoid that? How?
C.
cvanitterbeeck
Idea is to remove the timeouts at 60 seconds to shorten that.
