The Problem: i have configured a VG202 as a analouge gateway for 2 fax machines to work with CUCME. I have been unsuccessful in getting the inbound fax's to work. With the results of debugs showing the phone as busy. However the fax machine is able to send faxes externally.
Unable to make Inbound Fax calls
No Dial Tone
Fax does not answer incoming call
Fax drops out as busy in debug isdn q931
I was wondering if any body had has similar problem with this particular piece of hardware.
