VG202 Fax Trouble shooting
lukedp
Beginner
Beginner
The Problem: i have configured a VG202 as a analouge gateway  for 2 fax machines to work with CUCME. I have been unsuccessful in getting the inbound fax's to work. With the results of debugs showing the phone as busy. However the fax machine is able to send faxes externally.
  1. Unable to make Inbound Fax calls
    • No Dial Tone
    • Fax does not answer incoming call
    • Fax drops out as busy in debug isdn q931
I was wondering if any body had has similar problem with this particular piece of hardware.
Chris Deren
Hall of Fame Master Hall of Fame Master
Hall of Fame Master
What do you get when you simply call the extension of the fax?
Can you post config from your CME as well?
Is there a reason your are doing SCCP for fax with CME as oppose to H323 or SIP?
Can you post "debug voice dialpeer" from both routers?
Chris
Problem Solved,
Client placed the fax on the incorrect port.
Recognize Your Peers
