VG202 issue
Hello all
  I'm configuring a VG202 using the MGCP protocol. However, I get no ringback tone when I call to pstn. where I mistake please suggest me.see config below.
Show run
Building configuration...
Current configuration : 1612 bytes
! Last configuration change at 19:18:27 UTC Sun Mar 3 2002
version 15.4
no service pad
hostname VG202_FL10
boot-start-marker
boot-end-marker
enable password dmfdsnfjsf;lc,ljckz
no aaa new-model
ip cef
no ipv6 cef
voice service voip
voice-card 0
interface FastEthernet0/0
ip address 192.168.74.75 255.255.252.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
no ip forward-protocol nd
no ip http server
ip route 192.168.80.0 255.255.252.0 192.168.72.1
control-plane
voice-port 0/0
cptone TH
voice-port 0/1
mgcp
mgcp call-agent cucm.planetcomm.com 2427 service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
ccm-manager music-on-hold
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager config server 192.168.80.21
ccm-manager config
dial-peer voice 9990990 pots
service mgcpapp
port 0/0
dial-peer voice 9990099 pots
service mgcpapp
port 0/0
line con 0
no modem enable
line aux 0
line vty 0 4
login
transport input none
end
show ccm-manager
sh ccm-manager
MGCP Domain Name: VG202_FL10
Priority Status Host
Primary Registered cucm.planetcomm.com (192.168.80.21)
First Backup None
Second Backup None
Current active Call Manager: 192.168.80.21
Backhaul/Redundant link port: 2428
Failover Interval: 30 seconds
Keepalive Interval: 15 seconds
Last keepalive sent: 19:41:22 UTC Mar 3 2002 (elapsed time: 00:00:04)
Last MGCP traffic time: 19:41:22 UTC Mar 3 2002 (elapsed time: 00:00:04)
Last failover time: None
Last switchback time: None
Switchback mode: Graceful
MGCP Fallback mode: Not Selected
Last MGCP Fallback start time: None
Last MGCP Fallback end time: None
MGCP Download Tones: Disabled
TFTP retry count to shut Ports: 2
Configuration Auto-Download Information
Current version-id: 1450691134-c1bda8ec-fa7d-4487-8cd0-ec8c34108c01
Last config-downloaded:00:00:00
Current state: Waiting for commands
Configuration Download statistics:
Download Attempted : 1
Download Successful : 1
Download Failed : 0
TFTP Download Failed : 0
Configuration Attempted : 1
Configuration Successful : 1
Configuration Failed(Parsing): 0
Configuration Failed(config) : 0
Last config download command: New Registration
FAX mode: disable
Configuration Error History:
Show mgcp
MGCP Admin State ACTIVE, Oper State ACTIVE - Cause Code NONE
MGCP call-agent: cucm.planetcomm.com 2427 Initial protocol service is MGCP 0.1
MGCP validate call-agent source-ipaddr DISABLED
MGCP validate domain name DISABLED
MGCP block-newcalls DISABLED
MGCP send SGCP RSIP: forced/restart/graceful/disconnected DISABLED
MGCP quarantine mode discard/step
MGCP quarantine of persistent events is ENABLED
MGCP dtmf-relay for VoIP is SDP controlled
MGCP dtmf-relay for voAAL2 is SDP controlled
MGCP voip modem passthrough mode: NSE, codec: g711ulaw, redundancy: DISABLED,
MGCP voaal2 modem passthrough disabled
MGCP voip modem relay: Disabled
MGCP T.38 Named Signalling Event (NSE) response timer: 200
MGCP Network (IP/AAL2) Continuity Test timer: 200
MGCP 'RTP stream loss' timer disabled
MGCP request timeout 500
MGCP maximum exponential request timeout 4000
MGCP rtp unreachable timeout 1000 action notify
MGCP gateway port: 2427, MGCP maximum waiting delay 3000
MGCP restart delay 0, MGCP vad DISABLED
MGCP rtrcac DISABLED
MGCP system resource check DISABLED
MGCP xpc-codec: DISABLED, MGCP persistent hookflash: DISABLED
MGCP persistent offhook: ENABLED, MGCP persistent onhook: DISABLED
MGCP piggyback msg ENABLED, MGCP endpoint offset DISABLED
MGCP simple-sdp ENABLED
MGCP undotted-notation DISABLED
MGCP codec type g711ulaw, MGCP packetization period 20
MGCP JB threshold lwm 30, MGCP JB threshold hwm 150
MGCP LAT threshold lwm 150, MGCP LAT threshold hwm 300
MGCP PL threshold lwm 1000, MGCP PL threshold hwm 10000
MGCP CL threshold lwm 1000, MGCP CL threshold hwm 10000
MGCP playout mode is adaptive 60, 40, 1000 in msec
MGCP Fax Playout Buffer is 300 in msec
MGCP media (RTP) dscp: ef, MGCP signaling dscp: af31
MGCP default package: line-package
MGCP supported packages: gm-package dtmf-package trunk-package line-package
hs-package rtp-package atm-package ms-package dt-package
mt-package sst-package fxr-package md-package
MGCP Digit Map matching order: shortest match
SGCP Digit Map matching order: always left-to-right
MGCP VoAAL2 ignore-lco-codec DISABLED
MGCP T.38 Max Fax Rate is DEFAULT
MGCP T.38 Fax is DISABLED
MGCP T.38 Fax ECM is DISABLED
MGCP T.38 Fax NSF Override is DISABLED
MGCP T.38 Fax Low Speed Redundancy: 0
MGCP T.38 Fax High Speed Redundancy: 0
MGCP Fax relay SG3-to-G3: ENABLED
MGCP Fax relay ANSam suppression: DISABLED
MGCP control bind :DISABLED
MGCP media bind :DISABLED
MGCP Upspeed payload type for G711ulaw: 0, G711alaw: 8
MGCP Dynamic payload type for Cisco fax indication: 96, Cisco fax ack: 97
MGCP Dynamic payload type for G.726-16K codec
MGCP Dynamic payload type for G.726-24K codec
MGCP Dynamic payload type for G.726-32K codec
MGCP Dynamic payload type for G.Clear codec
MGCP Dynamic payload type for NSE is 100
MGCP Dynamic payload type for NTE is 99
MGCP rsip-range is enabled for TGCP only.
MGCP Comedia role is NONE
MGCP Comedia check media source is DISABLED
MGCP Comedia SDP force is DISABLED
MGCP g729 variants use static payload type and contain annexb in SDP
MGCP Guaranteed scheduler time is DISABLED
MGCP Disconnect delay error recovery DISABLED
MGCP DNS stale threshold is 30 seconds
11 Replies 11
Manish Gogna
Hi Nattapong,
It appears from the config that only one port is configured for VG202, even the two pots dial peers created by default are only for the same port 0/0. Can you check the cabling , do a shut / no shut on these voice ports and then reset the gateway from cucm.
Manish
- Do rate helpful posts -
Hi Manish
     I tried from you suggest me It still same symptom.
Nut
Can you post the latest "show run" and "show ccm-manager"
Manish
Please see file attach
Hi Nattapong, Since you now mention that the issue is 'No dialtone" , can you check if the no dialtone issue is seen for calls to PSTN or an IP phone registered to cucm ( assuming you have an Analog phone connected to the FXS port on VG202 ). Does the call actually connect and work despite the no ringback issue?
Manish
Hi Manish
-Yes I have analog phone conncted FXS port
At port fxs I config DN 8888 can call to IP Phone it work fine.
Hi Nattapong,
In that case the troubleshooting needs to be done on cucm or the gateway / trunk on the outbound call leg through which the call is going out.
Manish
Hi manish
    Now problem is solve thank you for help
Hi Manish
    Let me explain when I off-hook I get tone but when I call to pstn  no ringback tone anyway at analog phone have ringing
    I apologize get you confuse (I will change topic)
Nut
dapo100
Have you configured your fxs line in Call manager for the vg202 port 0/0?
Do you see the vg202 as registered? You may do the reset of the port via cucm GUi and not from the gateway itself.
Regards, Dan
Hello Dan
-Yes I have configured fxs line already
-Yes I do please see log previously at show ccm-manager it registered already
Nut
