VG204 Caller-ID Problem..
jin6486157
Hi all..
We are using vg204 with cucm 8.5.
We enabled caller-ID on vg204 and directory Number in cucm..
But it couldn't operate any anlaog phone.
So I upgraded version for Vg204 what is vg20x-ipvoice-mz.124-24.T6, vg20x-ipvoice-mz.150-1.M8 and vg20x-ipvoice-mz.151-3.T3.
it also can not operate on vg204 .
i assigned like this..
voice-port 2/3
cptone KR
timeouts ringing infinity
caller-id enable
voice-port 2/3
cptone KR
caller-id enable
Please tell me the solution..
Thanks.
boris.kudr
Hi Myung,
Can you see CallerID if you plug in a regular phone or CallerID device into the same line?
Please post "show run | i mgcp|ccm" from the gateway.
Cheers,
Boris
We are using a stcapp .  Directory number is normally registration on vg204
it's our vg 204 running config .
VG204#show run
Building configuration...
Current configuration : 2199 bytes
version 12.4
no service pad
boot-start-marker
boot system flash vg20x-ipvoice-mz.124-24.T6.bin
boot-end-marker
logging message-counter syslog
no aaa new-model
clock timezone KST 9
ip source-route
ip cef
no ip domain lookup
no ipv6 cef
stcapp ccm-group 1
stcapp
stcapp feature access-code
prefix *
pickup local *
stcapp supplementary-services
port 0/0
  fallback-dn 4170
port 0/1
  fallback-dn 4969
port 0/2
  fallback-dn 4254
port 0/3
  fallback-dn 4885
voice service voip
fax protocol cisco
voice-card 0
archive
log config
  hidekeys
interface FastEthernet0/0
ip address 1.1.1.1 255.255.255.0
speed 100
full-duplex
interface FastEthernet0/1
no ip address
speed 100
full-duplex
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 1.1.1.254 255.255.255.0
no ip http server
control-plane
voice-port 0/0
ring cadence pattern04
cptone KR
caller-id enable
voice-port 0/1
cptone KR
caller-id enable
voice-port 0/2
cptone KR
caller-id enable
voice-port 0/3
cptone KR
caller-id enable
ccm-manager sccp local FastEthernet0/0
sccp ccm 1.1.1.103 identifier 10 version 7.0
sccp ccm 1.1.1.102 identifier 20 version 7.0
sccp
sccp ccm group 1
associate ccm 10 priority 1
associate ccm 20 priority 2
switchback method graceful
dial-peer voice 1 pots
service stcapp
port 0/0
dial-peer voice 2 pots
service stcapp
port 0/1
dial-peer voice 3 pots
service stcapp
port 0/2
dial-peer voice 4 pots
service stcapp
port 0/3
dial-peer voice 101 voip
line con 0
password cisco
login
no modem enable
line aux 0
line vty 0 4
login
transport input all
exception data-corruption buffer truncate
end
VG204#
do you have resolve your problem ?
regards
I didn't .
Customer didn't want to using CID function .
do you have any resolve?
regards.
