VG204 no sound transmit
fernando.greco
MCGP configuration is ok - Registration is ok
Calls in both directions are ok
but i heard no sound from the analog telephone .
Can you help me ?
You're probably using G.729 with 12.4(24)T or something similar.
Try this:
mgcp behavior g729-variants static-pt
mgcp behavior dynamically-change-codec-pt disable
hth,
nick
Hi Nick,
I've tried this command but it's the same .
I've change the IOS version in 12.4.24-T1
and it's the same .
I've tested the gateway in my lab CCM 7.1.2 and it's worked very well.
My customer use the 7.0.2 and it's not work in this version ??? mistake ?
regards
Fernando
Hi Nick,
I solved my pb !
I used a vlan who be filtered in RTP in a sense.
By using the same vlan of the T2 gateway towards it's works.
Thank you for your help
