VG204 phones shows Registration Rejected
yogesh bhalerao
1)I have CCM and i have registered VG204 with CCM and it was working fine but now suddenly the phones connected on VG204 shows registration rejected,i am also attaching screenshot for the same
9 Replies 9
boris.kudr
Hi mate,
Did you reset the gateway in CUCM after you created lines?
Do you mind posting the gateway configuration (sccp/stcapp and dial-peers)?
What do you have on "show stcapp device summary"?
Cheers
Boris
____
Please rate helpful posts
Пожалуйста оценивайте полезные сообщения
Hi Mate,
            Thanks for your reply,i am attaching the config and the command output
have a look at the "show stcapp device summary":
Port       Device          Device   Call          Dev     Directory   Dev
Identifier Name            State    State         Type    Number      Cntl
0/0        AN1FCAF24268000 IS       IDLE           ALG     6002       CCM
0/1        AN1FCAF24268001 IS       IDLE           ALG     6099       CCM
0/2        AN1FCAF24268002 IS       IDLE           ALG     6068       CCM
0/3        AN1FCAF24268003 IS       ACTIVE         ALG     6148       CCM
the device names do not match MAC address from the CUCM gateway port configuration.
Try using correct MAC in CUCM gateway config and don't forget to reset the gateway after configuration update.
Cheers,
Boris
___
BTW it seems that this gateways ports are already registered with CUCM.
Are you sure you are looking at the right gateway?
___
Yes i am looking at my PRIMARY gateway 10.2.5.11 and there it shows that registration rejected
I will again check and come give me 5min
But these MAC addresses are the Vg204 MAC addresses of the 4 ports and they come automatically
ITs, the right gatway and correct VG204 Box i am js getting ngaged tone
now i am getting error
cmapp_sccp_tftp_download_file unable to get configuration file
