Hello, I have a quick question.
I have a VG224 configured using MGCP on callmanager 8.1. Port 1 on the VG224 is connected to a paging system. Caller dails the extension assigned to the VG224 port 1 to access the paging system.
Everything works fine but occasionally i have someone holds up the port so that everyone else dial that extension gets a busy signal. Is there a command that will show me the caller's extension that holds up the line?
I did a test and tried "show voice call status", it gives some kind of weird caller-ID which didnt much the test extension.
Thanks you all for your input!
