VG224 Concern
hbarrera2
I have to change the ip address on a subsciber ccm server. I currently have several vg224 registered to this subscriber in the ccm group.
I dont think so because they register to the ccm by way of mgcp and mac, so changing the ip should not kill the communication between my vg224's should it? I will also be re-ip'ing the vg224's as well.
Jaime Valencia
if you defined the call agent using IP then you do need to change it, or if using DNS make sure to modify all proper entries for name resolution
look at the MGCP config and if you're using IPs then modify them accordingly
java
if this helps, please rate
java
