02-18-2011 06:50 AM - edited 03-16-2019 03:32 AM
I am trying to set up a vg224 to work with CUCM.
I was following a config
1. enable
2. configure terminal
3. stcapp ccm-group group-id
4. stcapp
5. stcapp feature access-code
6. stcapp feature speed-dial
7. voice-port slot-number/port
8. timeouts initial seconds
Anway at step 4 I get:
STCAPP: Config error: SCCP stack not configured... exiting stcapp shutdown initiated... waiting for calls to clear.
Any Ideas what the problem might be, or how to fix it?
02-18-2011 08:54 AM
Hi Thomas,
Are the fXS ports registered to CUCM currently? You will haver to shutdown sccp to make any changes. What is the IOS version and the version of CUCM?
03-09-2011 12:49 PM
I needed to enable IP routing
03-18-2011 02:48 PM
Hi Thomas
I got the same Error,
My Version Software (vg224-I6S-M), Version 12.4(24)T5
My config
stcapp ccm-group 1
prefix #
call forward all 78
call forward cancel 79
pickup local 75
pickup group 74
interface FastEthernet0/0
ip address 192.168.100.X 255.255.255.0
duplex auto
speed auto
voice-port 2/0
timeouts ringing infinity
voice-port 2/1
mgcp fax t38 ecm
sccp local FastEthernet0/0
sccp ccm 192.168.100.x identifier 3 version 7.0
sccp ccm 192.168.100.x identifier 1 version 7.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate ccm 3 priority 3
dial-peer voice 1 pots
service stcapp
port 2/0
dial-peer voice 2 pots
service stcapp
port 2/1
VG-MCVG224-01# sh sccp all
SCCP Admin State: UP
Gateway Local Interface: FastEthernet0/0
IPv4 Address: 192.168.100.x
Port Number: 2000
IP Precedence: 5
User Masked Codec list: None
Call Manager: 192.168.100.11, Port Number: 2000
Priority: N/A, Version: 7.0, Identifier: 3
Trustpoint: N/A
Call Manager: 192.168.100.x, Port Number: 2000
Priority: N/A, Version: 7.0, Identifier: 1
Trustpoint: N/A
SCCP application services(dspfarm profiles) are not enabled
or haven't associated to SCCP CCM group
CCM Group Identifier: 1
Description: None
Binded Interface: None
Associated CCM Id: 1, Priority in this CCM Group: 1
Associated CCM Id: 3, Priority in this CCM Group: 3
Registration Retries: 3, Registration Timeout: 10 sec
Keepalive Retries: 3, Keepalive Timeout: 30 sec
CCM Connect Retries: 3, CCM Connect Interval: 10 sec
Switchover Method: GRACEFUL, Switchback Method: GRACEFUL_GUARD
Switchback Interval: 10 sec, Switchback Timeout: 7200 sec
Signaling DSCP value: cs3, Audio DSCP value: ef
Total number of active session(s) 0, and connection(s) 0
Total number of active session(s) 0, connection(s) 0, and callegs 0
SCCP Application Service(s) Statistics Summary:
Total Conferencing Sessions: 0, Connections: 0
Total Transcoding Sessions: 0, Connections: 0
Total MTP Sessions: 0, Connections: 0
Total ALG-Phone Sessions: 0, Connections: 0
Total BRI-Phone Sessions: 0, Connections: 0
Total SCCP Sessions: 0, Connections: 0
Total active sessions 0, connections 0, rsvp sessions 0
No SCCP server info to display
VG-MCVG224-01#VG-MCVG224-01#
VG-MCVG224-01#sh stcapp feature codes
malicious call ID (MCID) ***
prefix #
call forward all #78
call forward cancel #79
pickup local group #75
pickup different group #74
pickup direct #6
meetme-conference #5
stcapp feature speed-dial disabled
stcapp call-control mode is standard mode
VG-MCVG224-01#
I can't activate the STCAPP !!!
06-26-2015 05:34 PM
Hola que tal tengo el mismo error en el VG lo que hice y ya me funciono fue lo siguiente :
1.- negue los servicios de sccp y los di de baja
2.- los volvi a crear para que se firmara con el CUCM
3.- volvia generar los servicios de stcapp ccm-group 1
stcapp
4.- DONE !!!!
funciono mi vg se firma y despues de haberlo hecho ya funciono correctamente
INTENTENLO
