VG224 in MGCP can be helped by GW in SRST ?
MBO46
Beginner
Beginner
Hello everybody,
To have the VG224 operational in SRST, i configure it in SCCP on the CUCM.
If i use MGCP to configure VG224, can i have the voice gateway registered on the GW in SRST ?
Matthieu
Karthik Sivaram
Enthusiast
Enthusiast
Hello Matthieu,
I can think of 3 ways having srst with vg224 (3 options):
1.Changing the protocol of the VG224 to SCCP (easiest way to do it) as the following
example:
sccp local Loopback104
sccp ccm 10.104.20.101 identifier 101 version 4.1
sccp ccm 10.104.96.108 identifier 108 version 4.1
sccp ccm 10.104.96.104 identifier 104 version 4.1
sccp ccm 10.104.120.200 identifier 200 version 4.1
sccp
sccp ccm group 105
associate ccm 104 priority 1
associate ccm 108 priority 2
associate ccm 101 priority 3
associate ccm 200 priority 4
Where 10.104.120.200 is the SRST gateway. Add the srst reference in the device pool of the vg224
2.Applying the command the following commands to the MGCP gateway
ccm-manager fallback-mgcp
application
global
service alternate default
And configure dial-peers for H323 in case the router goes to SRST mode.
3.Convert the protocol to H323 and create 2 dial-peer one of them with preference 1 with
destination pattern , dial-peer two with preference 2 with
destination pattern
Hope this helps!
Karthik
Thanks Karthik,
I used only the first possibility, i will test the two others.
Hi Karthik,
I just followed SCCP configuration, however i can not dial out between VG224 and SRST IP phone.
do i need to have dial-peer no SCCP ?
I could see VG224 successfully registerted to SRST VGW by command show ephone registration.
HQ-Tokyo#sh ephone summary
ephone-1 Mac:0017.9551.F7EA TCP socket:[2] activeLine:0 REGISTERED
mediaActive:0 offhook:0 ringing:0 reset:0 reset_sent:0 debug:0
IP:142.100.64.102 7941   keepalive 38  1:2  CM Fallback
ephone-2 Mac:0017.954A.47B0 TCP socket:[1] activeLine:0 REGISTERED
IP:142.100.64.104 7971   keepalive 39  1:1 2:2  CM Fallback
ephone-3 Mac:5C26.0A27.4C00 TCP socket:[3] activeLine:0 REGISTERED
IP:192.168.128.150 CIPC   keepalive 35   CM Fallback
sp1:3001
ephone-4 Mac:FB9E.EB2E.C400 TCP socket:[4] activeLine:0 REGISTERED ----> VG224
IP:10.10.10.1 SCCP Gateway (AN)  keepalive 21   CM Fallback
ephone-5 Mac:FB9E.EB2E.CFFF TCP socket:[5] activeLine:0 REGISTERED  ----> VG224
IP:10.10.10.1 Unknown 30032  keepalive 21
however i can not see any destination pattern by command sh dial-peer voice summary.
HQ-Tokyo#sh dial-peer voice summary
dial-peer hunt 0
             AD                                    PRE PASS                OUT
TAG    TYPE  MIN  OPER PREFIX    DEST-PATTERN      FER THRU SESS-TARGET    STAT PORT
999300 pots    up   up                     0         down 3/0/0  ----> VG224 digits
20001  pots     up   up             2002$              0                           50/0/1
20002  pots     up   up             2001$              0                           50/0/2
