VG224 incoming calls not ringing device
ngaitan
IOS vg224-i6s-mz.124-4.T8.bin
I have a line used for a deaf user connected to VG224. The line has dial tone and can make calls out but incoming calls do not ring the phone. I have tried reloading the VG and resetting that port.
Here is the debug voip ccapi inout and debug vpm sig
HQVG224#config t
Enter configuration commands, one per line. End with CNTL/Z.
HQVG224(config)#voice-port 2/19
HQVG224(config-voiceport)#shut
HQVG224(config-voiceport)#no shut
HQVG224(config-voiceport)#^Z
HQVG224#sh voice port summ
                                     IN       OUT
PORT     CH   SIG-TYPE   ADMIN OPER STATUS   STATUS   EC
2/0       --  fxs-ls      up    dorm on-hook  idle     y
2/1       --  fxs-ls      up    dorm on-hook  idle     y
2/2       --  fxs-ls      down  down on-hook  idle     y
2/3       --  fxs-ls      up    dorm on-hook  idle     y
2/4       --  fxs-ls      up    dorm on-hook  idle     y
2/5       --  fxs-ls      up    dorm on-hook  idle     y
2/6       --  fxs-ls      up    dorm on-hook  idle   y
2/7       --  fxs-ls      up    dorm on-hook  idle     y
2/8       --  fxs-ls      up    dorm on-hook  idle     y
2/9       --  fxs-ls      up    dorm on-hook  idle     y
2/10     --  fxs-ls      up    dorm on-hook  idle     y
2/11     --  fxs-ls     up    dorm on-hook  idle     y
2/12     --  fxs-ls      up    dorm on-hook  idle     y
2/13     --  fxs-ls      up    dorm on-hook  idle     y
2/14     --  fxs-ls      up    dorm on-hook  idle     y
2/15     --  fxs-ls      up    dorm on-hook  idle    y
2/16     --  fxs-ls      up    dorm on-hook  idle     y
2/17     --  fxs-ls      up    dorm on-hook  idle     y
2/18     --  fxs-ls      up    dorm on-hook  idle     y
2/19     --  fxs-ls      up    dorm on-hook  idle     y
HQVG224#cl log
% Ambiguous command: "cl log"
HQVG224#clear log
Clear logging buffer [confirm]y
HQVG224#sh log
Syslog logging: enabled (1 messages dropped, 1 messages rate-limited,
                0 flushes, 0 overruns, xml disabled, filtering disabled)
    Console logging: disabled
    Monitor logging: level debugging, 0 messages logged, xml disabled,
                     filtering disabled
    Buffer logging: level debugging, 17467 messages logged, xml disabled,
                    filtering disabled
 Logging Exception size (4096 bytes)
    Count and timestamp logging messages: enabled
    Trap logging: level informational, 105 message lines logged
        Logging to 10.100.6.105(global) (udp port 514, audit disabled, link up),        105 message lines logged, xml disabled,
               filtering disabled
Log Buffer (500000 bytes):
008393: Feb 8 2019 12:03:56.386 CST: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupReque        stPrivate:
   Interface=0x63146298, Interface Type=6, Destination=, Mode=0x9,
   Call Params(Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened,        Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subsriber Type Str=, FinalDestinationFlag=FALSE, Outgoing Dial-peer=0, Call C        ount On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Appl        ication Call Id=A0000000027eb3f6000000F5)
008394: Feb 8 2019 12:03:56.390 CST: //186/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequ        estPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
008395: Feb 8 2019 12:03:56.390 CST: //186/xxxxxxxxxxxx/CCAPI/ccCallSetContext:
   Context=0x635533B8
008396: Feb 8 2019 12:03:56.390 CST: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupReque        stPrivate:
   Interface=0x62EFE2C8, Interface Type=9, Destination=0.0.0.0, Mode=0x9,
   Subsriber Type Str=, FinalDestinationFlag=FALSE, Outgoing Dial-peer=0, Call C        ount On=TRUE,
008397: Feb 8 2019 12:03:56.390 CST: //187/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequ        estPrivate:
   SPI Call Setup Request Is Success; Interface Type=9, FlowMode=1
008398: Feb 8 2019 12:03:56.390 CST: //187/xxxxxxxxxxxx/CCAPI/ccCallSetContext:
   Context=0x63552EE8
008399: Feb 8 2019 12:03:56.390 CST: htsp_timer_stop3
008400: Feb 8 2019 12:03:56.394 CST: //187/xxxxxxxxxxxx/CCAPI/cc_api_call_conne        cted:
   Interface=0x62EFE2C8, Data Bitmask=0x0, Progress Indication=NULL(0),
   Connection Handle=0
008401: Feb 8 2019 12:03:56.394 CST: //187/xxxxxxxxxxxx/CCAPI/cc_api_call_conne        cted:
   Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)htsp_setup_req
008402: Feb 8 2019 12:03:56.398 CST: htsp_process_event: [2/19, FXSLS_ONHOOK, E        _HTSP_SETUP_REQ]fxsls_onhook_setup
008403: Feb 8 2019 12:03:56.398 CST: //186/xxxxxxxxxxxx/CCAPI/cc_api_call_proce        eding:
   Interface=0x63146298, Progress Indication=NULL(0)
008404: Feb 8 2019 12:03:56.398 CST: //186/xxxxxxxxxxxx/CCAPI/ccCallModify:
   Nominator=0x1000, Params=0x6343FDB0, Call Id=186
008405: Feb 8 2019 12:03:56.398 CST: //186/xxxxxxxxxxxx/CCAPI/ccCallReportDigit        s:
   (callID=0xBA, digit_event=0x1, enable=TRUE, consume=FALSE)
008406: Feb 8 2019 12:03:56.398 CST: //186/xxxxxxxxxxxx/CCAPI/ccCallReportDigit        s:
   Enabled=TRUE, Call Id=186
008407: Feb 8 2019 12:03:56.402 CST: //186/xxxxxxxxxxxx/CCAPI/cc_api_call_repor        t_digits_done:
   (vdbPtr=0x63146298, callID=0xBA, disp=0, digit_event=0x1, enable=TRUE, consum        e=FALSE)
008408: Feb 8 2019 12:03:56.402 CST: //186/xxxxxxxxxxxx/CCAPI/cc_api_call_repor        t_digits_done:
   Enabled=TRUE, Disposition=0x0, Interface=0x63146298, Call Id=186
008409: Feb 8 2019 12:03:56.402 CST: //186/xxxxxxxxxxxx/CCAPI/cc_api_call_repor        t_digits_done:
   Call Entry(Initial Digit Timeout=10000(ms), Inter Digit Timeout=10000(ms))
008410: Feb 8 2019 12:03:56.402 CST: //186/xxxxxxxxxxxx/CCAPI/ccConferenceCreat        e:
   (confID=0x6343FF54, callID1=0xBA, callID2=0xBB, tag=0x0)
008411: Feb 8 2019 12:03:56.402 CST: //186/xxxxxxxxxxxx/CCAPI/ccConferenceCreat        e:
   Conference Id=0x6343FF54, Call Id1=186, Call Id2=187, Tag=0x0
008412: Feb 8 2019 12:03:56.402 CST: htsp_call_bridged invoked
008413: Feb 8 2019 12:03:56.402 CST: //186/xxxxxxxxxxxx/CCAPI/cc_api_bridge_don        e:
   Conference Id=0x55, Source Interface=0x63146298, Source Call Id=186,
   Destination Call Id=187, Disposition=0x0, Tag=0xFFFFFFFF
008414: Feb 8 2019 12:03:56.402 CST: //187/xxxxxxxxxxxx/CCAPI/cc_api_bridge_don        e:
   Conference Id=0x55, Source Interface=0x62EFE2C8, Source Call Id=187,
   Destination Call Id=186, Disposition=0x0, Tag=0x0
008415: Feb 8 2019 12:03:56.402 CST: //186/xxxxxxxxxxxx/CCAPI/cc_generic_bridge        _done:
008416: Feb 8 2019 12:03:56.402 CST: //186/xxxxxxxxxxxx/CCAPI/ccConferenceCreat        e:
   Call Entry(Conference Id=0x55, Destination Call Id=187)
008417: Feb 8 2019 12:03:56.402 CST: //187/xxxxxxxxxxxx/CCAPI/ccConferenceCreat        e:
   Call Entry(Conference Id=0x55, Destination Call Id=186)
008418: Feb 8 2019 12:03:56.402 CST: //186/xxxxxxxxxxxx/CCAPI/cc_api_caps_ind:
   Destination Interface=0x62EFE2C8, Destination Call Id=187, Source Call Id=186        ,
   Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
   Modem=0x2, Codec Bytes=20, Signal Type=3)
008419: Feb 8 2019 12:03:56.402 CST: //186/xxxxxxxxxxxx/CCAPI/cc_api_caps_ind:
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=200(ms), Fax Nom=300(ms))
008420: Feb 8 2019 12:03:56.406 CST: //187/xxxxxxxxxxxx/CCAPI/cc_api_caps_ind:
   Destination Interface=0x63146298, Destination Call Id=186, Source Call Id=187        ,
   Caps(Codec=0x1, Fax Rate=0x2, Vad=0x1,
   Modem=0x2, Codec Bytes=160, Signal Type=2)
008421: Feb 8 2019 12:03:56.406 CST: //187/xxxxxxxxxxxx/CCAPI/cc_api_caps_ind:
   Playout Max=250(ms), Fax Nom=300(ms))
008422: Feb 8 2019 12:03:56.406 CST: //187/xxxxxxxxxxxx/CCAPI/cc_api_caps_ack:
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=OFF(0x1),
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=1895)
008423: Feb 8 2019 12:03:56.406 CST: //186/xxxxxxxxxxxx/CCAPI/cc_api_caps_ack:
008424: Feb 8 2019 12:03:56.406 CST: //186/xxxxxxxxxxxx/CCAPI/cc_process_notify        _bridge_done:
   Conference Id=0x55, Call Id1=186, Call Id2=187
008425: Feb 8 2019 12:03:56.410 CST: //186/xxxxxxxxxxxx/CCAPI/cc_api_call_modif        y_done:
   Result=0, Interface=0x63146298, Call Id=186
008426: Feb 8 2019 12:03:56.410 CST: htsp_process_event: [2/19, FXSLS_WAIT_OFFH        OOK, E_HTSP_VOICE_CUT_THROUGH]fxsls_waitoff_voice
008427: Feb 8 2019 12:03:56.414 CST: //186/xxxxxxxxxxxx/CCAPI/cc_api_voice_mode        _event:
   Call Id=186
008428: Feb 8 2019 12:03:56.414 CST: //186/xxxxxxxxxxxx/CCAPI/cc_api_voice_mode        _event:
   Call Entry(Context=0x635533B8)
008429: Feb 8 2019 12:03:56.414 CST: htsp_process_event: [2/19, FXSLS_WAIT_OFFH        OOK, E_HTSP_VOICE_CUT_THROUGH]fxsls_waitoff_voice
008430: Feb 8 2019 12:03:56.414 CST: //186/xxxxxxxxxxxx/CCAPI/ccCallFeature:
   Feature Type=24, Call Id=186htsp_call_feature:feature 24
008431: Feb 8 2019 12:03:56.414 CST: [2/19] htsp_set_caller_id_tx_time Caller I        D:FSK_DURING_RING
008432: Feb 8 2019 12:03:56.418 CST: htsp_process_event: [2/19, FXSLS_WAIT_OFFH        OOK, E_HTSP_CALLERID_RINGING]fxsls_onhook_callerid
008433: Feb 8 2019 12:03:56.418 CST: [2/19] c2400_ring_gen: ring1_cadence_on=25        0 ring1_cadence_off=500 ring2_cadence_on=0 ring2_cadence_off=0 ring3_cadence_on=        0 ring3_cadence_off=0 ring4_cadence_on=0 ring4_cadence_off=0 ring5_cadence_on=0        ring5_cadence_off=0 ring6_cadence_on=0 ring6_cadence_off=0
008434: Feb 8 2019 12:03:56.418 CST: [2/19] c2400_set_sig_state: ABCD=0, timest        amp=0, sys_time=86220472htsp_alert
008435: Feb 8 2019 12:03:56.418 CST: //186/xxxxxxxxxxxx/CCAPI/cc_api_call_alert        :
   Interface=0x63146298, Progress Indication=INBAND(8), Signal Indication=SIGNAL        RINGBACK(1)
008436: Feb 8 2019 12:03:56.418 CST: //186/xxxxxxxxxxxx/CCAPI/cc_api_call_alert        :
   Call Entry(Retry Count=0, Responsed=TRUE)
008437: Feb 8 2019 12:03:56.482 CST: [2/19] do_ring_cadence IDLE->ON (2000)
008438: Feb 8 2019 12:03:58.482 CST: [2/19] do_ring_cadence ON->OFF (4000)
008439: Feb 8 2019 12:03:59.842 CST: htsp_timer_stop3
008440: Feb 8 2019 12:03:59.846 CST: //186/xxxxxxxxxxxx/CCAPI/cc_api_voice_mode        _event:
   Call Id=186
008441: Feb 8 2019 12:03:59.846 CST: //186/xxxxxxxxxxxx/CCAPI/cc_api_voice_mode        _event:
008442: Feb 8 2019 12:03:59.846 CST: htsp_process_event: [2/19, FXSLS_WAIT_OFFH        OOK, E_HTSP_VOICE_CUT_THROUGH]fxsls_waitoff_voice
008443: Feb 8 2019 12:04:02.482 CST: [2/19] do_ring_cadence OFF->ON (2000)
008444: Feb 8 2019 12:04:04.482 CST: [2/19] do_ring_cadence ON->OFF (4000)
HQVG224#sh log
                     filtering disabled
    Buffer logging: level debugging, 17482 messages logged, xml disabled,
                    filtering disabled
             filtering disabled
008393: Feb 8 2019 12:03:56.386 CST: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
   Subsriber Type Str=, FinalDestinationFlag=FALSE, Outgoing Dial-peer=0, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=A0000000027eb3f6000000F5)
008394: Feb 8 2019 12:03:56.390 CST: //186/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
   Context=0x635533B8
008396: Feb 8 2019 12:03:56.390 CST: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
   Subsriber Type Str=, FinalDestinationFlag=FALSE, Outgoing Dial-peer=0, Call Count On=TRUE,
008397: Feb 8 2019 12:03:56.390 CST: //187/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
   Context=0x63552EE8
008400: Feb 8 2019 12:03:56.394 CST: //187/xxxxxxxxxxxx/CCAPI/cc_api_call_connected:
   Connection Handle=0
008401: Feb 8 2019 12:03:56.394 CST: //187/xxxxxxxxxxxx/CCAPI/cc_api_call_connected:
008402: Feb 8 2019 12:03:56.398 CST: htsp_process_event: [2/19, FXSLS_ONHOOK, E_HTSP_SETUP_REQ]fxsls_onhook_setup
008403: Feb 8 2019 12:03:56.398 CST: //186/xxxxxxxxxxxx/CCAPI/cc_api_call_proceeding:
008405: Feb 8 2019 12:03:56.398 CST: //186/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
008406: Feb 8 2019 12:03:56.398 CST: //186/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
008407: Feb 8 2019 12:03:56.402 CST: //186/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x63146298, callID=0xBA, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
008408: Feb 8 2019 12:03:56.402 CST: //186/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
008409: Feb 8 2019 12:03:56.402 CST: //186/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
008410: Feb 8 2019 12:03:56.402 CST: //186/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
008411: Feb 8 2019 12:03:56.402 CST: //186/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
008413: Feb 8 2019 12:03:56.402 CST: //186/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
008414: Feb 8 2019 12:03:56.402 CST: //187/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
008415: Feb 8 2019 12:03:56.402 CST: //186/xxxxxxxxxxxx/CCAPI/cc_generic_bridge_done:
008416: Feb 8 2019 12:03:56.402 CST: //186/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
008417: Feb 8 2019 12:03:56.402 CST: //187/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   Destination Interface=0x62EFE2C8, Destination Call Id=187, Source Call Id=186,
   Destination Interface=0x63146298, Destination Call Id=186, Source Call Id=187,
008424: Feb 8 2019 12:03:56.406 CST: //186/xxxxxxxxxxxx/CCAPI/cc_process_notify_bridge_done:
008425: Feb 8 2019 12:03:56.410 CST: //186/xxxxxxxxxxxx/CCAPI/cc_api_call_modify_done:
008426: Feb 8 2019 12:03:56.410 CST: htsp_process_event: [2/19, FXSLS_WAIT_OFFHOOK, E_HTSP_VOICE_CUT_THROUGH]fxsls_waitoff_voice
008427: Feb 8 2019 12:03:56.414 CST: //186/xxxxxxxxxxxx/CCAPI/cc_api_voice_mode_event:
   Call Id=186
008428: Feb 8 2019 12:03:56.414 CST: //186/xxxxxxxxxxxx/CCAPI/cc_api_voice_mode_event:
008429: Feb 8 2019 12:03:56.414 CST: htsp_process_event: [2/19, FXSLS_WAIT_OFFHOOK, E_HTSP_VOICE_CUT_THROUGH]fxsls_waitoff_voice
008431: Feb 8 2019 12:03:56.414 CST: [2/19] htsp_set_caller_id_tx_time Caller ID:FSK_DURING_RING
008432: Feb 8 2019 12:03:56.418 CST: htsp_process_event: [2/19, FXSLS_WAIT_OFFHOOK, E_HTSP_CALLERID_RINGING]fxsls_onhook_callerid
008433: Feb 8 2019 12:03:56.418 CST: [2/19] c2400_ring_gen: ring1_cadence_on=250 ring1_cadence_off=500 ring2_cadence_on=0 ring2_cadence_off=0 ring3_cadence_on=0 ring3_cadence_off=0 ring4_cadence_on=0 ring4_cadence_off=0 ring5_cadence_on=0 ring5_cadence_off=0 ring6_cadence_on=0 ring6_cadence_off=0
008434: Feb 8 2019 12:03:56.418 CST: [2/19] c2400_set_sig_state: ABCD=0, timestamp=0, sys_time=86220472htsp_alert
008435: Feb 8 2019 12:03:56.418 CST: //186/xxxxxxxxxxxx/CCAPI/cc_api_call_alert:
008436: Feb 8 2019 12:03:56.418 CST: //186/xxxxxxxxxxxx/CCAPI/cc_api_call_alert:
008440: Feb 8 2019 12:03:59.846 CST: //186/xxxxxxxxxxxx/CCAPI/cc_api_voice_mode_event:
   Call Id=186
008441: Feb 8 2019 12:03:59.846 CST: //186/xxxxxxxxxxxx/CCAPI/cc_api_voice_mode_event:
008442: Feb 8 2019 12:03:59.846 CST: htsp_process_event: [2/19, FXSLS_WAIT_OFFHOOK, E_HTSP_VOICE_CUT_THROUGH]fxsls_waitoff_voice
008445: Feb 8 2019 12:04:06.402 CST: //186/xxxxxxxxxxxx/CCAPI/cc_handle_inter_digit_timer:
   Generate inter-digit timeout CC_EV_CALL_DIGIT_END event
008446: Feb 8 2019 12:04:08.482 CST: [2/19] do_ring_cadence OFF->ON (2000)
008447: Feb 8 2019 12:04:10.482 CST: [2/19] do_ring_cadence ON->OFF (4000)
008448: Feb 8 2019 12:04:14.483 CST: [2/19] do_ring_cadence OFF->ON (2000)
008449: Feb 8 2019 12:04:16.483 CST: [2/19] do_ring_cadence ON->OFF (4000)
008450: Feb 8 2019 12:04:20.483 CST: [2/19] do_ring_cadence OFF->ON (2000)
008451: Feb 8 2019 12:04:22.483 CST: [2/19] do_ring_cadence ON->OFF (4000)
008452: Feb 8 2019 12:04:26.483 CST: [2/19] do_ring_cadence OFF->ON (2000)
008453: Feb 8 2019 12:04:28.483 CST: [2/19] do_ring_cadence ON->OFF (4000)
008454: Feb 8 2019 12:04:32.483 CST: [2/19] do_ring_cadence OFF->ON (2000)
008455: Feb 8 2019 12:04:34.483 CST: [2/19] do_ring_cadence ON->OFF (4000)
008456: Feb 8 2019 12:04:38.483 CST: [2/19] do_ring_cadence OFF->ON (2000)
008457: Feb 8 2019 12:04:40.483 CST: [2/19] do_ring_cadence ON->OFF (4000)
HQVG224#
HQVG224#sh voice call status
CallID     CID  ccVdb      Port        DSP/Ch  Called #   Codec    Dial-peers
0xBA       0    0x63146298 2/19        0/1:1  *           g711ulaw 0/99920
1 active call found
ngaitan
here is the config for the port:
HQVG224#show voice port 2/19
Foreign Exchange Station 2/19 Slot is 2, Port is 19
 Type of VoicePort is FXS
 Operation State is DORMANT
 Administrative State is UP
 The Last Interface Down Failure Cause is Administrative Shutdown
 Description is not set
 Noise Regeneration is enabled
 Non Linear Processing is enabled
 Non Linear Mute is disabled
 Non Linear Threshold is -21 dB
 Music On Hold Threshold is Set to -38 dBm
 In Gain is Set to 0 dB
 Out Attenuation is Set to 0 dB
 Echo Cancellation is enabled
 Echo Cancellation NLP mute is disabled
 Echo Cancellation NLP threshold is -21 dB
 Echo Cancel Coverage is set to 64 ms
 Echo Cancel worst case ERL is set to 6 dB
 Playout-delay Mode is set to adaptive
 Playout-delay Nominal is set to 60 ms
 Playout-delay Maximum is set to 250 ms
 Playout-delay Minimum mode is set to default, value 40 ms
 Playout-delay Fax is set to 300 ms
 Connection Mode is normal
 Connection Number is not set
 Initial Time Out is set to 10 s
 Interdigit Time Out is set to 10 s
 Call Disconnect Time Out is set to 60 s
 Supervisory Disconnect Time Out is set to 750 ms
 Ringing Time Out is set to 180 s
 Wait Release Time Out is set to 30 s
 Companding Type is u-law
 Region Tone is set for US
 Analog Info Follows:
 Currently processing none
 Maintenance Mode Set to None (not in mtc mode)
 Number of signaling protocol errors are 0
 Impedance is set to 600r Ohm
 Analog interface A-D gain offset = -3.0 dB
 Analog interface D-A gain offset = -3.0 dB
 FXS idle voltage set to high
 alt-battery-feed set to feed1
 Ring DC offset set to 0 volt
 Station name None, Station number None
 Translation profile (Incoming):
 Translation profile (Outgoing):
 Voice card specific Info Follows:
 Signal Type is loopStart
 Ring Frequency is 25 Hz
 Hook Status is On Hook
 Ring Active Status is inactive
ngaitan
and dial peer config:
HQVG224#show dial-peer voice 99920
VoiceEncapPeer99920
        peer type = voice, system default peer = FALSE, information type = voice        ,
        description = `',
        tag = 99920, destination-pattern = `',
        answer-address = `', preference=0,
        CLID Restriction = None
        CLID Network Number = `'
        CLID Second Number sent
        CLID Override RDNIS = disabled,
        source carrier-id = `', target carrier-id = `',
        source trunk-group-label = `',  target trunk-group-label = `',
        numbering Type = `unknown'
        group = 99920, Admin state is up, Operation state is up,
        Outbound state is down,
        incoming called-number = `', connections/maximum = 0/unlimited,
        DTMF Relay = disabled,
        URI classes:
            Destination =
        huntstop = disabled,
        in bound application associated: 'mgcpapp'
        out bound application associated: ''
        dnis-map =
        permission :both
        incoming COR list:maximum capability
        outgoing COR list:minimum requirement
        incoming call blocking:
        translation-profile = `'
        disconnect-cause = `no-service'
        advertise 0x40 capacity_update_timer 25 addrFamily 0 oldAddrFamily 0
        type = pots, prefix = `',
        forward-digits default
        session-target = `', voice-port = `2/0',
        direct-inward-dial = disabled,
        digit_strip = enabled,
        register E.164 number with H323 GK and/or SIP Registrar = TRUE
        fax rate = system,   payload size =  20 bytes
        supported-language = ''
        Time elapsed since last clearing of voice call statistics never
        Connect Time = 0, Charged Units = 0,
        Successful Calls = 0, Failed Calls = 0, Incomplete Calls = 0
        Accepted Calls = 0, Refused Calls = 0,
        Last Disconnect Cause is "",
        Last Disconnect Text is "",
        Last Setup Time = 0.
        Last Disconnect Time = 0.
