06-02-2010 02:36 AM - edited 03-15-2019 11:03 PM
Hi All,
I am new to Cisco IPT.
I would like to integrate Vg224 with CUCM8. The VG224 will be used to connect FAX & Analog Phones.
Could you please let me know which protocol (H323/MGCP/SSCp) should I use to integrate with CUCM.
Nirmal
06-02-2010 03:14 AM
SCCP will provide the best line-side feature support.
06-02-2010 03:18 AM
Thanks for your quick suggestion. I have a small query on it.
Will FAX work fine with SCCP configuration mode ?
Nirmal
06-02-2010 03:26 AM
Yes if properly configured; Fax relay, either Cisco-proprietary or T.38 must be supported by both the VG224 IOS and PSTN gateway. It also must be configured appropriatly.
The Cisco IOS Fax, Modem, and Text Support over IP Configuration Guide, Release 12.4T is a good place to start.
06-02-2010 03:33 AM
Thanks for your quick support.
