VG224 IOS recommendation
ppellettiere
vg224-i6s-mz.124-24.T6.bin is our current IOS. We seem to have issues with ports locking up
and end up re-booting the gateway.
We also would like to connect to the gateway using SSH and TACACS.
Any Suggestions?
Chris Deren
15.1.4M4 has been stable for me.
In order to get SSH access you need to make sure you purchased the proper secured IOS for VG224, it is different from default and is available for download on CCO.
HTH,
Chris
Chris Deren
HTH,
Chris
Thanks for the information
I agree with Chris recommendation, uses that version myself without any problem so far.
Please rate all useful posts.
Response Signature
