VG224 MGCP can´t register to CUCM 8.6.2-20000-2
Nelsonmejia09
I have tried to register cisco VG224 to CUCM 8.6 like MGCP gateway but it fail to register, any idea why this issue?
24 Replies 24
Ayodeji Okanlawon
Can you send the sh run of the vg224?
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
Hi this is the config about MGCP:
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 10.24.130.11
ccm-manager config
mgcp
mgcp call-agent 10.24.130.11 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp validate domain-name
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface FastEthernet0/0
mgcp bind media source-interface FastEthernet0/0
mgcp profile default
Do you have the dial-peers configured for the Vg224 ports with mgcp enabled on them
e.g
dial-peer voice 1 pots
service mgcp
port 0/0
No, there is not, because is a new VG.
You need to configure dial-peers each for the fxs port on the vg224 and you need to enable them for mgcp as I mentioned above.
I have configured 24 dial-peers, but VG doesn´t register.
dial-peer voice 24 pots
service mgcpapp
port 2/23
After the config..please do the ff:
conf t
no mgcp
mgcp
I habe done all steps but its the same.
it can be a bug?
please do "debug mgcp packet" then do no mgcp, mgcp
send the debug.
did you configure the FQDN of the gateway in CUCM. Do you have ip domain name configured on the gateway? if you do you need to add the domina name to the gateway name in cucm...
Yes I have configure the FQDN of the gateway in CUCM.
Debug logs Are:
VGALP01(config)#
*Mar  1 01:59:49.927: //-1/xxxxxxxxxxxx/MGCP/mgcpapp_process_sys_msg(208):[lvl=0]MGCP sys msg: (EXTERNAL_EVENT)
*Mar  1 01:59:49.927: //-1/xxxxxxxxxxxx/MGCP/xlate_mgcp_sys_ev(69):[lvl=0]xlate sys msg: (EXTERNAL_EVENT, 63FE0988)
*Mar  1 01:59:49.927: //-1/xxxxxxxxxxxx/MGCP/mgcpapp_process_sys_msg(217):[lvl=0]sys msg values: (INVALID MGCP EVENT, 0,  , 3647, CALL_IDLE)
*Mar  1 01:59:49.927: //-1/xxxxxxxxxxxx/MGCP/mgcp_handle_cmapp_event(442):[lvl=0]process
*Mar  1 01:59:49.927: //-1/xxxxxxxxxxxx/MGCP/xgcp_endpt_get_by_ifn(1330):[lvl=0]Entered
*Mar  1 01:59:49.927: //-1/xxxxxxxxxxxx/MGCP/xgcp_endpt_get_tree_link_by_ifn(1149):[lvl=0]Entered
*Mar  1 01:59:49.927: //-1/xxxxxxxxxxxx/MGCP/xgcp_endpt_compute_key(198):[lvl=0]type -1 slot FFFFFFFF subunit 0000
*Mar  1 01:59:49.927: //-1/xxxxxxxxxxxx/MGCP/xgcp_endpt_get_tree_link_by_ifn(1161):[lvl=0]computed key 0xF0000000
*Mar  1 01:59:49.927: //-1/xxxxxxxxxxxx/MGCP/mgcp_cmapp_send_rsip(407):[lvl=1]Send-RSIP: Sending gw host is VGALP01.volcan.com, endpt is *
*Mar  1 01:59:49.927: //-1/xxxxxxxxxxxx/MGCP/mgcp_root_get_profile(1905):[lvl=0]Entered
*Mar  1 01:59:49.927: //-1/xxxxxxxxxxxx/MGCP/mgcp_send_rsip_msg(737):[lvl=0]Entered
*Mar  1 01:59:49.927: //-1/xxxxxxxxxxxx/MGCP/mgcp_build_packet(864):[lvl=0]Entered
*Mar  1 01:59:49.927: //-1/xxxxxxxxxxxx/MGCP/mgcp_estimate_msg_buf_length(496):[lvl=1]328 bytes needed for header
*Mar  1 01:59:49.927: //-1/xxxxxxxxxxxx/MGCP/mgcp_estimate_msg_buf_length(785):[lvl=1]344 bytes needed after checking parameter lines
*Mar  1 01:59:49.927: //-1/xxxxxxxxxxxx/MGCP/mgcp_estimate_msg_buf_length(808):[lvl=1]344 bytes needed  after cheking SDP lines
*Mar  1 01:59:49.927: //-1/xxxxxxxxxxxx/MGCP/mgcp_build_parameter_lines(9499):[lvl=0]Entered
*Mar  1 01:59:49.927: //-1/xxxxxxxxxxxx/MGCP/mgcp_val_mandatory_parms(13005):[lvl=0]Entered
*Mar  1 01:59:49.931: //-1/xxxxxxxxxxxx/MGCP/mgcp_build_restart_method(12063):[lvl=0]Entered
*Mar  1 01:59:49.931: //-1/xxxxxxxxxxxx/MGCP/mgcp_build_restart_method(12085):[lvl=0]SUCCESS: Building Restart Method (RM:) OK
*Mar  1 01:59:49.931: //-1/xxxxxxxxxxxx/MGCP/mgcp_build_parameter_lines(9802):[lvl=0]SUCCESS: Building MGCP Parameter lines is OK
*Mar  1 01:59:49.931: //-1/xxxxxxxxxxxx/MGCP/mgcp_build_packet(1018):[lvl=1]SUCCESS: MGCP message building OK - END of building
*Mar  1 01:59:49.931: //-1/xxxxxxxxxxxx/MGCP/MGCP_NEDB_get_next_addr(1211):[lvl=1]
NOTIFY ENTITY = 10.24.130.11
next->10.24.130.11
*Mar  1 01:59:49.931: MGCP Packet sent to 10.24.130.11:2427--->
RSIP 957884407 *@VGALP01.volcan.com MGCP 0.1
RM: restart
*Mar  1 01:59:49.931: //-1/xxxxxxxxxxxx/MGCP/mgcp_endpt_record_rsip(615):[lvl=0]Entered
*Mar  1 01:59:49.931: //-1/xxxxxxxxxxxx/MGCP/mgcp_send_rsip_msg(882):[lvl=1]Manually recroding RSIP method
*Mar  1 01:59:49.931: //-1/xxxxxxxxxxxx/MGCP/mgcp_enq_retx_rsip_msg(396):[lvl=0]Entered
*Mar  1 01:59:49.931: //-1/xxxxxxxxxxxx/MGCP/mgcp_add_trans_id_rec(1137):[lvl=1]Add trans id (957884407, 646D36B8) record
*Mar  1 01:59:49.931: //-1/xxxxxxxxxxxx/MGCP/mgcp_stw_timer_start(393):[lvl=0]timer type 0, duration 500
*Mar  1 01:59:49.931: //-1/xxxxxxxxxxxx/MGCP/mgcp_stw_timer_start(393):[lvl=0]timer type 15, duration 20000
*Mar  1 01:59:49.935: //-1/xxxxxxxxxxxx/MGCP/mgcp_count_active_mgc_msg_stat(239):[lvl=1]MGC stat - 10.24.130.11, total=47, succ=0, failed=46
*Mar  1 01:59:49.935: MGCP Packet received from 10.24.130.11:2427--->
500 957884407
*Mar  1 01:59:49.935: //-1/xxxxxxxxxxxx/MGCP/mgcpapp_process_mgcp_msg(3536):[lvl=0] :
*Mar  1 01:59:49.935: //-1/xxxxxxxxxxxx/MGCP/mgcp_parse_packet(312):[lvl=0]call mgcp_parse_header
*Mar  1 01:59:49.935: //-1/xxxxxxxxxxxx/MGCP/mgcp_parse_packet(316):[lvl=0]out mgcp_parse_header
*Mar  1 01:59:49.935: //-1/xxxxxxxxxxxx/MGCP/mgcp_parse_packet(326):[lvl=1]SUCCESS: - MGCP Header parsing was OK
*Mar  1 01:59:49.935: //-1/xxxxxxxxxxxx/MGCP/mgcp_parse_packet(344):[lvl=2]SUCCESS: - END of Parsing
*Mar  1 01:59:49.935: //-1/xxxxxxxxxxxx/MGCP/mgcp_msg_ack(6687):[lvl=0]Entered
*Mar  1 01:59:49.935: //-1/xxxxxxxxxxxx/MGCP/mgcp_count_active_mgc_msg_stat(239):[lvl=1]MGC stat - 10.24.130.11, total=47, succ=0, failed=47
*Mar  1 01:59:49.935: //-1/xxxxxxxxxxxx/MGCP/mgcp_mp_get_not_entity(830):[lvl=2]Invalid parameter (pkt 0x640982F8 pkt->mgcp_parm_lines 0x00000000)
*Mar  1 01:59:49.935: //-1/xxxxxxxxxxxx/MGCP/mgcp_check_for_redirection(6548):[lvl=1]endpt * was not redirected
*Mar  1 01:59:49.935: //-1/xxxxxxxxxxxx/MGCP/mgcp_msg_ack(6759):[lvl=1]Removing msg : RSIP 957884407 *@VGALP01.demo.com MGCP 0.1
RM: restart
*Mar  1 01:59:49.935: //-1/xxxxxxxxxxxx/MGCP/mgcp_msg_ack(6831):[lvl=0] Received ACK for RSIP, setting the restart method to NONE
*Mar  1 01:59:49.935: //-1/xxxxxxxxxxxx/MGCP/mgcp_check_and_send_pending_rsip(2116):[lvl=0]Entered
*Mar  1 01:59:49.935: //-1/xxxxxxxxxxxx/MGCP/mgcp_check_endpt_ext_and_free_rsip_info(3320):[lvl=0]Entered
*Mar  1 01:59:49.939: //-1/xxxxxxxxxxxx/MGCP/mgcpapp_process_socket(3647):[lvl=0]Entered
*Mar  1 02:00:19.927: //-1/xxxxxxxxxxxx/MGCP/mgcpapp_process_sys_msg(208):[lvl=0]MGCP sys msg: (EXTERNAL_EVENT)
*Mar  1 02:00:19.927: //-1/xxxxxxxxxxxx/MGCP/xlate_mgcp_sys_ev(69):[lvl=0]xlate sys msg: (EXTERNAL_EVENT, 63FE099C)
*Mar  1 02:00:19.927: //-1/xxxxxxxxxxxx/MGCP/mgcpapp_process_sys_msg(217):[lvl=0]sys msg values: (INVALID MGCP EVENT, 0,  , 3647, CALL_IDLE)
*Mar  1 02:00:19.927: //-1/xxxxxxxxxxxx/MGCP/mgcp_handle_cmapp_event(442):[lvl=0]process
*Mar  1 02:00:19.927: //-1/xxxxxxxxxxxx/MGCP/xgcp_endpt_get_by_ifn(1330):[lvl=0]Entered
*Mar  1 02:00:19.927: //-1/xxxxxxxxxxxx/MGCP/xgcp_endpt_get_tree_link_by_ifn(1149):[lvl=0]Entered
*Mar  1 02:00:19.927: //-1/xxxxxxxxxxxx/MGCP/xgcp_endpt_compute_key(198):[lvl=0]type -1 slot FFFFFFFF subunit 0000
*Mar  1 02:00:19.927: //-1/xxxxxxxxxxxx/MGCP/xgcp_endpt_get_tree_link_by_ifn(1161):[lvl=0]computed key 0xF0000000
*Mar  1 02:00:19.927: //-1/xxxxxxxxxxxx/MGCP/mgcp_cmapp_send_rsip(407):[lvl=1]Send-RSIP: Sending gw host is VGALP01.volcan.com, endpt is *
*Mar  1 02:00:19.927: //-1/xxxxxxxxxxxx/MGCP/mgcp_root_get_profile(1905):[lvl=0]Entered
*Mar  1 02:00:19.927: //-1/xxxxxxxxxxxx/MGCP/mgcp_send_rsip_msg(737):[lvl=0]Entered
*Mar  1 02:00:19.927: //-1/xxxxxxxxxxxx/MGCP/mgcp_build_packet(864):[lvl=0]Entered
*Mar  1 02:00:19.927: //-1/xxxxxxxxxxxx/MGCP/mgcp_estimate_msg_buf_length(496):[lvl=1]328 bytes needed for header
*Mar  1 02:00:19.927: //-1/xxxxxxxxxxxx/MGCP/mgcp_estimate_msg_buf_length(785):[lvl=1]344 bytes needed after checking parameter lines
*Mar  1 02:00:19.927: //-1/xxxxxxxxxxxx/MGCP/mgcp_estimate_msg_buf_length(808):[lvl=1]344 bytes needed  after cheking SDP lines
*Mar  1 02:00:19.927: //-1/xxxxxxxxxxxx/MGCP/mgcp_build_parameter_lines(9499):[lvl=0]Entered
*Mar  1 02:00:19.927: //-1/xxxxxxxxxxxx/MGCP/mgcp_val_mandatory_parms(13005):[lvl=0]Entered
*Mar  1 02:00:19.931: //-1/xxxxxxxxxxxx/MGCP/mgcp_build_restart_method(12063):[lvl=0]Entered
*Mar  1 02:00:19.931: //-1/xxxxxxxxxxxx/MGCP/mgcp_build_restart_method(12085):[lvl=0]SUCCESS: Building Restart Method (RM:) OK
*Mar  1 02:00:19.931: //-1/xxxxxxxxxxxx/MGCP/mgcp_build_parameter_lines(9802):[lvl=0]SUCCESS: Building MGCP Parameter lines is OK
*Mar  1 02:00:19.931: //-1/xxxxxxxxxxxx/MGCP/mgcp_build_packet(1018):[lvl=1]SUCCESS: MGCP message building OK - END of building
*Mar  1 02:00:19.931: //-1/xxxxxxxxxxxx/MGCP/MGCP_NEDB_get_next_addr(1211):[lvl=1]
next->10.24.130.11
*Mar  1 02:00:19.931: MGCP Packet sent to 10.24.130.11:2427--->
RSIP 957884409 *@VGALP01.demo.com MGCP 0.1
RM: restart
This are the correct logs:
*Mar  1 01:59:49.927: //-1/xxxxxxxxxxxx/MGCP/mgcp_cmapp_send_rsip(407):[lvl=1]Send-RSIP: Sending gw host is VGALP01.demo.com, endpt is *
next->10.24.130.11
RM: restart
500 957884407
RM: restart
*Mar  1 02:00:19.927: //-1/xxxxxxxxxxxx/MGCP/mgcp_cmapp_send_rsip(407):[lvl=1]Send-RSIP: Sending gw host is VGALP01.demo.com, endpt is *
next->10.24.130.11
RM: restart
Hi Nelson,
Take a look at my post here and see if it helps:
https://supportforums.cisco.com/message/3793242#3793242
Not sure what all MGCP debugs you enabled, ideally just debug mgcp packets would have been. If possible, just post that debug while doing a no mgcp/mgcp.
Also, please post the show run, show ccm-manager, screenshot of the VG224 gateway config page.
Harmit.
this is the show run:
VGALP01#sh run
Building configuration...
Current configuration : 2081 bytes
hostname VGALP01
boot-start-marker
boot system flash slot0:vg224-i6s-mz.124-24.T8.bin
boot-end-marker
logging message-counter syslog
no aaa new-model
clock timezone GMT -5
ip source-route
ip cef
no ip domain lookup
ip domain name demo.com
no ipv6 cef
voice-card 0
archive
log config
  hidekeys
ip address 10.24.130.13 255.255.254.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 10.24.130.1
ip http server
control-plane
voice-port 2/0
voice-port 2/1
voice-port 2/2
voice-port 2/3
voice-port 2/4
voice-port 2/5
voice-port 2/6
voice-port 2/7
voice-port 2/8
voice-port 2/9
voice-port 2/10
voice-port 2/11
voice-port 2/12
voice-port 2/13
voice-port 2/14
voice-port 2/15
voice-port 2/16
voice-port 2/17
voice-port 2/18
voice-port 2/19
voice-port 2/20
voice-port 2/21
voice-port 2/22
voice-port 2/23
ccm-manager mgcp
ccm-manager config
mgcp
mgcp sdp simple
service mgcpapp
port 2/0
dial-peer voice 2 pots
service mgcpapp
port 2/1
dial-peer voice 3 pots
service mgcpapp
port 2/2
dial-peer voice 4 pots
service mgcpapp
port 2/3
dial-peer voice 5 pots
service mgcpapp
port 2/4
dial-peer voice 6 pots
service mgcpapp
port 2/5
dial-peer voice 7 pots
service mgcpapp
port 2/6
dial-peer voice 8 pots
service mgcpapp
port 2/7
dial-peer voice 9 pots
service mgcpapp
port 2/8
dial-peer voice 10 pots
service mgcpapp
port 2/9
dial-peer voice 11 pots
service mgcpapp
port 2/10
dial-peer voice 12 pots
service mgcpapp
port 2/11
dial-peer voice 13 pots
service mgcpapp
port 2/12
dial-peer voice 14 pots
service mgcpapp
port 2/13
dial-peer voice 15 pots
service mgcpapp
port 2/14
dial-peer voice 16 pots
service mgcpapp
port 2/15
dial-peer voice 17 pots
service mgcpapp
port 2/16
dial-peer voice 18 pots
service mgcpapp
port 2/17
dial-peer voice 19 pots
service mgcpapp
port 2/18
dial-peer voice 20 pots
service mgcpapp
port 2/19
dial-peer voice 21 pots
service mgcpapp
port 2/20
dial-peer voice 22 pots
service mgcpapp
port 2/21
dial-peer voice 23 pots
service mgcpapp
port 2/22
service mgcpapp
port 2/23
************* SHOW ccm- manager *********
VGALP01#sh ccm-manager
MGCP Domain Name: VGALP01.demo.com
Priority        Status                   Host
Primary         Registering with CM      10.24.130.11
First Backup    None
Second Backup   None
Current active Call Manager:    None
Backhaul/Redundant link port:   2428
Failover Interval:              30 seconds
Keepalive Interval:             15 seconds
Last keepalive sent:            11:15:55 GMT Nov 24 2012 (elapsed time: 2d06h)
Last MGCP traffic time:         18:05:29 GMT Nov 26 2012 (elapsed time: 00:00:27)
Last failover time:             None
Last switchback time:           None
Switchback mode:                Graceful
MGCP Fallback mode:             Enabled/ON
Last MGCP Fallback start time:  17:38:59 GMT Nov 26 2012
Last MGCP Fallback end time:    None
MGCP Download Tones:            Disabled
TFTP retry count to shut Ports: 2
Configuration Error History:
FAX mode: disable
VGALP01#
