Highlighted
Hall of Fame Master
VG224 MOH support
Looking at CUCM SRND Table "Cisco Analog Gateway Features” indicates that MOH is not supported on VG224. Can anyone confirm that this is true for unicast and multicast MOH?
Chris
2 ACCEPTED SOLUTIONS
Highlighted
VG224 MOH support
Chris,
MoH on SCCP VG224 is not supported. It is supported with H323/SIP/MGCP as per following -
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/7x/moh.html#wp1043577
Udit
Highlighted
VG224 MOH support
Chris,
Unicast with SCCP will work.
MCast won't work because of  -
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsb60015
The above bug is not the reason but just a confirmation tha MCast is not supported.
Udit
5 REPLIES 5
Highlighted
VG224 MOH support
Chris,
Udit
Highlighted
Hall of Fame Master
VG224 MOH support
Yeah, I saw that, but since it lists both unicast/multicat support I was not sure if this was the case for either one or both.
Chris
Highlighted
VG224 MOH support
I can say that for sure that Multicast is not supported with SCCP. Let me confirm about Unicast.
Udit
Highlighted
VG224 MOH support
Chris,
Udit
Highlighted
Hall of Fame Master
VG224 MOH support
Thanks.
Chris
